Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 10-03-2006, 11:10 PM
Purple_Haze Purple_Haze is offline
Question HIDs and 2003 1500 is that possible?
I have had a Jeep Grand Cherokee Overland that used 9006 bulbs for lights/low beams, had problems with it and it was considered a lemon by chrysler after 2 months of owning it, so i had it returned to the dealership and traded it in for a 2003 Ram Pickup. The problem with the Overland was that it used low beams instead of High for DRLs. That meant my HIDs would flicker(improper voltage for the ballasts) when in AUTO mode. I had to have my lights dial turned to ON position all the time to use the HIDs. My question is: i would love to use the HIDs in the pickup truck, i know it uses 9007 bulbs so yes, i know i will have to use different bulbs, but are the DRLs in it using the low or high beam? If they are using the low beam circuit i will not be able to unless i get my wiring figured out with the relays etc... but if in High, i will be ok, could someone answer that? Thanks!!
Old 10-12-2006, 12:03 AM
Re: HIDs and 2003 1500 is that possible?
btt!
Old 10-12-2006, 07:29 PM
anyone knows about any dodge ram forums?
dodgeforum.com ... just found it NM
