Old 10-03-2006, 09:36 PM
babuhr babuhr is offline
shaking at takeoff
Over the last few weeks, my S-10 ('97, 4.3L, 5spd 4WD) has began shaking when I takeoff from a stop. Its fine if I'm rolling even a little bit. Its also fine when cruising (no vibrations ect...). I just can't get going from a stop without it shaking pretty badly. I don't know if its a clutch issue, something with the driveshafts, u-joints, or what? Any help is appreciated.
Old 10-05-2006, 09:28 PM
wilfie27 wilfie27 is offline
Re: shaking at takeoff
Sounds like your trunion bearing which is the bearing your yoke rides on that goes into your differential. There is a crush sleeve that is inbetween your trunion nut and the bearing that will wear over time, which will allow some endplay allowing the vibration. You are probably leaking fluid out of the seal in front of the differential also. A new crush sleeve and seal should do the trick.
94 Firebird: 3.4L 220,000 mi
95 Blazer: LS 2DR/2WD 210,000 mi
96 Trans Port: work in progress
97 Silverado 4X4 Ex/cab: 200,000 mi
05 Malibu: 98K mi
08 Chevy Van: Direct TV work van
Old 10-06-2006, 12:01 AM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Sounds like a clutch problem.
1995 Factory Blazer Service Manual for sale, PM if interested.
