Go Back   Automotive Forums Car Chat > Isuzu > Trooper | SLX | Bighorn | Wizard
Old 10-03-2006, 08:16 PM
gold trooper gold trooper is offline
oil light flickers on morning commute
on the way to work my oil light starts to flicker on and off after about 10 miles then when i slow down to turn the light goes off and stays off till the next morning. changed oil filter thought maybe that was plugged, changed oil sending unit no progress. oil pressure gauge doesnt move when light is flickering.
Old 10-05-2006, 05:09 AM
atfdmike's Avatar
atfdmike atfdmike is offline
Re: oil light flickers on morning commute
There are actually two oil pressure sending units on your Trooper. One is for the idiot light, the other is for the guage. You might check to see that you got the right one for the light. You can test the light by simply grounding the connector to the wiring harness while ignition is on. Light should come on steady. Good luck
Oil Pressure Sender Oil Pressure Sending Unit With Light8943129400 With Gauge8970332900
Old 01-08-2007, 10:43 PM
Just added a mechanical oil pressure guage. Started engine, oil pressure started out at 70 psi and then dropped slowly down to 18 psi in about 5 min. What is going on? This is driving me nuts!!!! Actually this vehicle isn't driving me anywhere now. Its parked until I can fix it.
Old 01-09-2007, 12:10 AM
trooperbc's Avatar
trooperbc trooperbc is offline
that's about right and normal. if anything, the 18 psi might be a bit high, though it might come down more with more driving.
pressure will be much higher when the oil is cold. and drop as you say.
edit add:quote: """You can test the light by simply grounding the connector to the wiring harness while ignition is on. Light should come on steady""" if you do the suggest test and the light is steady on, try cleaning the contacts for that switch/sensor and see if that does it before replacing it.
//bc
1992 trooper 3.2L v6 sohc automatic...as is
i love a good intermittent electrical challenge. . .especially when it's someone else's.
Old 01-12-2007, 12:31 AM
Ramblin Fever Ramblin Fever is offline
If your oil is flowing good - no blockages in the oil passages and not too thick of an oil - 18psi at idle is about perfect.
I personally wouldn't want to see it below 10psi at idle on a warm engine, but 15-20 psi on a warm engine at idle is fine.
1997 3.2L V6 Rodeo
32" Yoko's, 16x8 MB Wheels, 2" lift, Brushguard, KC Fog's, Loadwarrior Rack
On it's way to 185k strong
2004 3.4L Tacoma TRD off-road 4x4 Double cab
32" Yoko's, Westin Bull-bar, KC Fogs 60K miles
Old 01-16-2007, 06:54 PM
2eyefishclaw's Avatar
2eyefishclaw 2eyefishclaw is offline
Send a message via AIM to 2eyefishclaw Send a message via Yahoo to 2eyefishclaw
remove the oil pan not the entire thing just the smaller part the screen for th oil pump pick up has been sucked up against the tube restricting oil flow or there is trash in the bottom of the pan that settels whit engine off and when running it will get pulled to the tube or you may have both siutations going on
