Old 10-03-2006, 07:42 PM
1957Buick 1957Buick is offline
Trans Mount
Took 98 Park Ave in for a state insp. I did ask the service writer to have the car looked over really well especially the brakes. He came back and said there was a broken transmission mount that had to be replaced to pass inspection. Brakes would pass but would need replacing soon. I told him to go ahead and do both. I got the old parts for the trans mount. It was not broken but it seems there is a bushing or spacer of some sort associated with that mount which does seem worn out. But the bracket itself is neither cracked or broken. Do you only get the rubber bushing/spacer with a new bracket or has my dealer fed me another line of BS? $315.33 for just the part . . . Could anyone clarify this for me?
Old 10-03-2006, 08:34 PM
rhandwor rhandwor is offline
Re: Trans Mount
I would go to a parts store and get a quote for a mount. Double the price and add $80.00 labor 1 hr.shouldn't be over $100.00 for the job.
Old 10-03-2006, 08:37 PM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
Question Re: Trans Mount
Welcome to AF!
First of all, which mount was it? Look at the pic below and you will see an item number for each one. Post back with the number of the one that was replaced. (I have never of a car failing inspection due to a bad trans mount!)
Old 10-03-2006, 10:23 PM
Re: Trans Mount
Edit: The part looks like #13 the rear trans mount.. What bugs me is that the rubber seems to be all that is worn out. The physical bracket I have is neither cracked or broken.
Old 10-04-2006, 07:30 AM
niccaleb112602 niccaleb112602 is offline
Re: Trans Mount
Originally Posted by 1957Buick
The part looks like #8. What bugs me is that the rubber seems to be all that is worn out. The physical bracket I have is neither cracked or broken.
It's the rubber that wears out due to age, wear and tear, and driving conditions. And yes you have to buy the whole unit, not just the rubber.
Old 10-04-2006, 09:05 AM
Re: Trans Mount
Very expensive piece of rubber, Thanks
Old 10-04-2006, 06:50 PM
HotZ28's Avatar
AF Moderator Elite
Re: Trans Mount
The problem with the 1998 PA, is that you cannot find an aftermarket mount at any of the neighborhood part stores. Usually, the left front mount breaks before the others (Item #10). Do you have the part number on the invoice? If so, was it;
# 22201112 LF Trans mount Item # 10 $130 bucks + shipping
# 22178776 LR Trans mount rear Item #13 $77 bucks + shipping
Yes, both are a very expensive piece of rubber; however, both items can be purchased from GM Parts Direct, for 100% less than what you paid. Hate to be the one to rub salt into the wound, however, I assume you have already concluded, the dealer made a good profit on your part & repairs!
Old 10-04-2006, 08:19 PM
Re: Trans Mount
Part #22201116
Old 10-05-2006, 09:55 AM
HotZ28's Avatar
AF Moderator Elite
Re: Trans Mount
WOW, that is a ridiculous price for a piece of rubber!
Item # 12 GM PART # 22201116
Transmission Mounting Mount
QTY: 1 GM LIST: $316.12
