Go Back   Automotive Forums Car Chat > Nissan > Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35
Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 Excellent platform and the good ol' VQ30DE and VQ35DE engines.
Old 10-03-2006, 07:41 PM
tysib tysib is offline
Bose stereo
My stereo on my 2000 maxima stopped working. I relaced the fuse it worked then I hit a bump and it blew the fuse again. Now when I replace the fuse it dosn't work. Before it stopped the bose stereo itself felt like it was loose and bounced around a little making noise. What should I do? Plese help.
Old 10-14-2006, 11:47 PM
Mrbizness1 Mrbizness1 is offline
Re: Bose stereo
If the fuse you replaced only controls the radio then you probably have an internal problem. If it seems loose then you might want to pull off the cover plate and check the connection plugs. I bought one on ebay from a seller named xw1600. He was the only seller that would give any warranty. He will also rebuild your own unit. The dealer wanted $350.00 to have mine repaired.
The have to sent it to California and it takes almost a month to get it back.
