Old 09-03-2002, 07:07 PM
FiestaSI FiestaSI is offline
Send a message via AIM to FiestaSI
ECU reset now my accord wont turn over
I reset my ECU in my Honda Accord SE 97 and after doing so the engine wont turn over. the ignition clicks but no spark...
any guesses ?
A>
Old 09-03-2002, 09:53 PM
tenguzero tenguzero is offline
Did you check all your fuses?
(k) TZero publications. All rights reversed. Reprint what you like. Fnord
Old 09-03-2002, 10:03 PM
yes all the fuses seem fine
Old 09-03-2002, 10:28 PM
ShockJon ShockJon is offline
What does the car do exactly?? When you turn the key what sounds does it make?? and also what did you do to the car to have to reset the ECU??? If you have antitheft you have to program it to tell it you are not a theif...
Old 09-03-2002, 10:32 PM
well the starter makes a clicking noise like it is trying to turn the engine over, and i am getting full power so i know it is not the battery... it acts as if the engine is stuck and the starter cant crank it over or something...
i reset it because i just changed the intake on it... nothing that would involve anything major... i have reset it b4 and it has done fine...
A>
Old 09-04-2002, 12:26 AM
It sounds like a bad electrical connection or a fried starter!!! Thats the only thing I can think of by not being able to touch it and hear it...
Old 09-04-2002, 01:46 PM
i was being dumb or something....
the battery was drained just enough so that it wouldnt turn over....
i flipped on the stereo just for some tunes and when the bass hit the cars electrical cut out, and disconnecting the amp proved the cars electrical to turn back on.... so whats the lesson here...
well pulling a fuse wont kill the starter, but it may for some reason drain the battery if the car is in the "on" position...
__
on another note i must say that it did make a difference resetting the ECU, my car even sounds richer...
i went out and drove it hard for a few, and at first it felt like i had wasted 4 grand on modifications because it was driving like a fucking geo metro, after a few mins driving it started to catch up with it self, it idels better, has a deeper exhaust sound, has smoother incline around 5000 rpms (i was having a bit of a dip from there to 6500). not huge differences, but definatly noticable for anyone who "listens" to thier car.
i would sugest this little operation to anyone who has made even the smallest modifications to thier engine.
thanks for your help guys
A> out
Old 09-04-2002, 08:19 PM
xpel xpel is offline
Just curious,
How did you reset your ECU????
***ORIGINAL PUREHONDA.COM MEMBER SINCE JULY 2000***Black 1994 Honda Accord EX*Angel Eye Euro Style Projector Lamp 3 Lens with Black/Clear*PIAA Super Plasma H3 Bulbs*PIAA 1200 Series clear driving lens* S-Type Style Tail Lamp (Carbon)*JDM Spec Black Color Corner Lamp *All Clear corners*Type R Style Grill with Mesh*Red AEM Cold Air intake*Magnaflow Euro Stainless Steel Full CatBack Exhaust System*EIbach Sportline Springs*Koni Adjustable Special D" (Reds) Front Shocks*Koni Adjustable Sports (Yellow) Rear Shocks*17" KMC Unit Chrome*Kumho Ecsta Supra 215/17/45*Indiglo Guage (2 way)*Momo Racing Pedals*Type R Gear Knob*Pioneer DEH-P7200 in dash CD receiver*Kenwood KFC-1687(Fronts)*Infinity Kappa 693.3i (Rear)*Rockford Fosgate Punch 200.4.*CODE Pro 300 alarm system
Old 09-05-2002, 01:03 AM
You are supposed to unhook the negative side of the batt for a couple of minutes.... I always un hook both sides of the batt..... The longer you can leave it unhooked the better chance of it TOTALLY resetting...
Old 09-07-2002, 05:39 PM
ECU RESET
actually just unpluging something does not always reset it
ie new VCRs, they manage to keep thier time on them... (well mine does)
it is a computer, so it has a back up battery, just like all computers.
so to reset it, you need to start your car, and open the hood and fuse box under the hood and pull the ECU fuse and the radio/back-up fuse as well. the car will cut off when you do this, give it about 10 seconds, then take the keys out of the ignition and put the fuses back in, start the car, and blam, it is reset, usually the car hesitates a little when you try to start it up...
EOF
A>
