Old 10-03-2006, 04:58 PM
98blazer/97jimmy 98blazer/97jimmy is offline
ignition switch
i recently replaced my ignition switch and now when i shut the car off and take the key out the accessory lights stay on as does the radio. If i put the key back in and turn it forward just a little the lights and radio will shut off but then i cant take the key out. did i goof something up when i put the switch in or is the switch a faulty piece. thanks for any help
Old 10-04-2006, 08:32 AM
billibong's Avatar
billibong billibong is offline
Re: ignition switch
Do the radio and lights stay on when you open the door after taking out the key? Blazers have a courtesy circuit that leaves the power to the radio for about fifteen minutes and to the accesory lights for about a minute or so after the ignition is off and the key is removed.
billibong
99 4X4 Blazer LS Vin W
Repairs:
U/L Ball Joints, I/O Tie Rod Ends, New Tie Rod Adjusting Sleeves, New Idler Arm, R & L Front Hubs, R & L Upper CA Bushings, New Gabriel Ultramax Shocks (what a difference)
F & R Brakes and Rotors at 110,000.
Infinity Speakers to replace the blown factory sets.
162K+ and still kicking.
Old 10-04-2006, 04:29 PM
Re: ignition switch
yeah, after i open the door and close it and walk away the radio will still be playing and the overhead console stays on that says the temp. the dome light will shut off but not those two things. it acts as if the key is in the ignition but turned backward where you can run the radio without the car on.
