Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 10-03-2006, 04:51 PM
FreshBubble FreshBubble is offline
Tire Pressure
What PSI do yall fill your tires up to?
1994 Chevrolet Caprice Classic 4.3L
Old 10-03-2006, 05:41 PM
HLandin's Avatar
HLandin HLandin is offline
Re: Tire Pressure
Set it to the recommended amount. The sticker on the driver's side door says 35 PSI. You could also check in you owner's manual. The important thing is what the max rating for the tire is because the air will heat up and expand while driving. You don't want to exceed the rating of your tires (mine are 44 PSI max) found on the tires themselves.
Old 10-03-2006, 06:37 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: Tire Pressure
I usually run mine between 32 and 36 PSI, depending on the make of the tire.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 10-03-2006, 08:14 PM
CD Smalley CD Smalley is offline
Re: Tire Pressure
Depends on what the TIRE maker says.
I wouldn't go by the sticker on the door. Does anyone remember what happened with Ford Explorers and Firestone tires???
Ford said to user a lower pressure than Firestone did. Bad things happened.
CD
1991 W41 #142
1989 Caprice 9C1
1997 C1500
1997 Bonnie SE
1998 Olds 98 LS
Recently updated: http://forums.b-body.org
Old 10-03-2006, 09:35 PM
silicon212's Avatar
Confoundingly Lucid
Re: Tire Pressure
Exactly.
The stickers on the door are valid for the ORIGINAL EQUIPMENT TIRES ONLY, in MOST cases, unless of course you're Ford. In that deal, Firestone recommended 32PSI, Ford recommended 24PSI (for a better ride, according to Ford).
Old 10-04-2006, 11:31 AM
bobss396's Avatar
bobss396 bobss396 is offline
Send a message via AIM to bobss396
Re: Tire Pressure
I run my '84 wagon between 32-34 all around.
Old 10-04-2006, 06:35 PM
GreyGoose006 GreyGoose006 is offline
Re: Tire Pressure
would someone PLEASE go over to the ENG/TECHNICAL forum and look in the tire pressure thread. those people are contradicting this exact thing...
Old 10-04-2006, 09:59 PM
JustSayGo JustSayGo is offline
Send a message via AIM to JustSayGo Send a message via Skype™ to JustSayGo
Re: Tire Pressure
Let them fill their tires as they see fit.Those guys sound like they are clutching at their chest with both hands and sticking one leg outta bed. They have a fairly clear understanding of 1975 tire technology and refuse to ackowledge the improvements that TIRE manufactures are continuosly making every day.
I pretty sure that none of the major TIRE manufactures will be consulting these guys asking for their recomendations on tire inflation any time soon.
Thirty years ago American cars weighed 4-6,000lbs and all tires said 28-32 lbs max inflation on the sidewall. Todays cars weigh around 3,000 lbs and in many cases have much wider tires than the typical 70's auto. There has been a trend of gradually increasing tire inflation recomendations by TIRE manufactures over the past 30 years. Now we have tires that say 44lbs max PSI on them on realetivly light weight vehicles. Tire pressures are cold and should not be adjusted as heat increases tire pressure.
Modern automobile tires are far more sophisticated than comparing them to an illustrative example of a party balloon having limited structure. Modern technology of tire construction continues to reduce irregular tire wear problems that over years past were blamed totally on tire inflation. Engineers who design tires are blending construction and inflation together to develope and produce longer lasting, safer, and more fuel efficient tires. Before a tire design ever leaves the computer drawing board, the engineers know what the tire should do at the tire pressure it has been designed to work at.
If your tires are the size recommended by the AUTO manufacture, the max tire pressure molded into the side wall by the TIRE manufacture will not create a liability to them or cause the tire to dervolope undisirable characteristics, contact patch, or otherwise reduce safety.
Old 10-05-2006, 05:11 AM
Re: Tire Pressure
Well said!
CD
1991 W41 #142
1989 Caprice 9C1
1997 C1500
1997 Bonnie SE
1998 Olds 98 LS
