Old 10-03-2006, 04:46 PM
philritz philritz is offline
Big Big Trouble
I broke one of my spark plugs off in the engine.totally lost it is my only means of transportation,i should be at work right now,guess what i can't go.HELP someone don't know what to do.1994 s10 2.2 manual.All replies will be greatly appreciated.
Old 10-03-2006, 04:55 PM
alblogg's Avatar
alblogg alblogg is offline
Re: Big Big Trouble
You say you broke it off do you mean you striped out the hole or is the spark plug still in there or is it out
'99 Blazer LT Loaded, K&N Filter, Pioneer Super
Tuner,Viper
'98 Pontiac Grand Prix GT, 3.8
'88 K1500 Cheyenne, 5.0, stock, bought new
'86 Nissan 720 Trash Truck
'69 C/10 step side, 307, all original, second owner, in process of restore.
The person who says it cannot be done should not interrurt the person doing it.
Share your knowledge. It is a way to achieve immortality.
Allen- Paintman
Wrenchtwister
Broompusher
Old 10-03-2006, 05:02 PM
Re: Big Big Trouble
still in there
Old 10-03-2006, 05:15 PM
alblogg's Avatar
Re: Big Big Trouble
So you broke the white top part off the plug
Tuner,Viper
Allen- Paintman
Wrenchtwister
Broompusher
Old 10-03-2006, 05:20 PM
Re: Big Big Trouble
nope just the thread snapped off in engine
Old 10-03-2006, 05:28 PM
alblogg's Avatar
Re: Big Big Trouble
Well my friend you are in deep s@*! but there is a way out of this. Take one of your spark plugs and go to your auto parts store and tell them what you did. They will sell you a little kit call a heli-core which is new threads and the tool to put them in the hole you have. They have these special for spark plugs and aluminum but be sure to take a spark plug with you to get the right size.
Tuner,Viper
Allen- Paintman
Wrenchtwister
Broompusher
Old 10-03-2006, 05:37 PM
Re: Big Big Trouble
thanks for the info muchly appreciated
Old 10-04-2006, 02:50 AM
DelCoch's Avatar
DelCoch DelCoch is offline
Re: Big Big Trouble
I think he's saying he twisted the spark plug off and the threads of the spark plug are still in the head. At this point a heli-coil won't do him a lot of good, as he needs to remove the rest of the spark plug.
You're best bet is to pull the head and then remove the remains of the spark plug with an easy-out. I have done it with the head on the vehicle using penetrating oil, an easy-out and applying heat with a torch; but not on an aluminum head, which are easy to damage.
I would soak it for 24 hrs with the best penetrating oil your auto parts store sells, WD-40 won’t do it; you need something stronger. Spray it every couple of hours for 24 hrs and then try to take it out with an easy-out. You may have to drill a small hole through it to get the easy-out started. In either case you will no doubt end up with pieces of metal falling down inside the cylinder, which will have to be removed to prevent damage when the engine is started.
In which case, if you’re successful in getting the rest of the plug out, you can turn the engine over with the starter, with that spark plug removed, for a few seconds to blow out the cylinder. Then start the engine with that spark plug still removed. This may blow all the debris out of the cylinder, but it’s not guaranteed to. Thus, it’s best to remove the head to make this type of repair.
P.S. When replacing spark plugs in aluminum heads always use an anti-siege compound on the threads of the spark plugs when installing them.
Old 10-04-2006, 04:04 PM
alblogg's Avatar
Re: Big Big Trouble
I am sorry I miss understood. I thought he was in deep s@#$ with the problem I thought he had sounds worst with your scenario.
Tuner,Viper
Allen- Paintman
Wrenchtwister
Broompusher
Old 10-05-2006, 01:40 PM
Re: Big Big Trouble
inerds came out in 1 piece ...got the sucker out... found a buddy with easyouts lubricated threads over nite easyout worked great new plugs in purrs thanks guys
Old 10-05-2006, 01:58 PM
alblogg's Avatar
Re: Big Big Trouble
Glad to hear it all worked out for you without having to tear down any thing.
Tuner,Viper
Allen- Paintman
Wrenchtwister
Broompusher
Old 10-06-2006, 03:45 AM
DelCoch's Avatar
Re: Big Big Trouble
Always nice to hear happy endings! Congrats on getting er done.
