Transmission Cooling Lines
A customer of mine has a rusted (leaking) transmission cooling line on his '92 Caprice. I've checked all over for pre-formed tubing and nobody seems to have any. It seems a pain to take the old line off and try to make the bends with the proper fittings etc. but may be the only course of action to take. Just wondering if anybody has run across this job on one of their Caprices? If so did you bend a line or find a pre-formed line or line set somewhere? Thanks, Formzy
Re: Transmission Cooling Lines
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1! 2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness! 1967 El Camino L79/M20 old school asphalt raper Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have. |
I had the same problem with my 87, they had rotted out where they go into my radiator, I cutted out the rotted part and put a rubber hose between it.
If you go the rubber hose route, make sure the clamps are tight, I had quite a adventure when I didnt tighten mine enough.
1987 Chevrolet Caprice classic Brougham. 142,000 on the 305 and still chugging
