Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 10-03-2006, 10:22 AM
jlpmba jlpmba is offline
4L30E Bang Shifting into 3rd
1996 Honda Passport, 2WD, 4spd Auto.
Just had the trans rebuilt and noticed
that when when shifting into third the engine revs up and
"slams" into third. It also "slams", not as bad, back into first
when stopping.
Shifting from 1-2 is okay.
Transmission shop is giving me the run around. what do you
all think?
Old 10-03-2006, 10:31 AM
Ramblin Fever Ramblin Fever is offline
Re: 4L30E Bang Shifting into 3rd
How many miles are on this tranny - before the rebuild? What's the history on maintenance?
Could be the range mode sensor is dirty; but the 4L30-E typically doesn't do well being rebuilt.
I only hope AAMCO's not involved in yours, they seem to like to tell everyone they need rebuilds when in fact there's nothing wrong. They told me this at 70k miles on my tranny, I now have 162k on the same transmission.
1997 3.2L V6 Rodeo
32" Yoko's, 16x8 MB Wheels, 2" lift, Brushguard, KC Fog's, Loadwarrior Rack
On it's way to 185k strong
2004 3.4L Tacoma TRD off-road 4x4 Double cab
32" Yoko's, Westin Bull-bar, KC Fogs 60K miles
Old 10-03-2006, 10:39 AM
tranny had approx 162K mi before it went out, fluid was changed every 60K.
AAMCO was not involved.
The tranny shop even went to say they "swapped" it with another
and it does the same thing, telling me its a PCM problem.
Old 10-03-2006, 10:48 AM
amigo-2k amigo-2k is offline
Isuzu Guy
uh oh ....
-Ryan
Isuzu Moderator
Car Show Tips
Operations manager with a results-driven passion for process improvement
FAQ 98-04 Isuzu Rodeo, Rodeo Sport, Amigo, Trooper
SOLD - NOV2015 - 2000 Amigo, V6, HT winter, ST summer, 2wd
Old 10-03-2006, 10:56 AM
surferfletch surferfletch is offline
No way. 200K+! He's had a bad enough year already.
Old 10-03-2006, 11:31 AM
Uh-Oh...
Sorry All, I don't understand. This is my first post on this site.
Old 10-03-2006, 11:34 AM
Isuzu Guy
sorry about that, I'm just pointing out you both have 162k on your rigs.
-Ryan
Isuzu Moderator
Car Show Tips
Old 10-03-2006, 11:41 AM
I do believe I ran across this thread where the trans would not shift at all.
Mine does at a high RPM, but, it did not do that before.
Old 10-03-2006, 11:44 AM
Dober89 Dober89 is offline
From what you described it sounds like the clutches are slipping from 2-3 and then when they do engage, because the engine is revving thats why it bangs into 3rd gear. I know these transmissions arent the greatest but if they did a good rebuild it should be working alot better.
What was happening with the transmission before you brought it to the shop??
I can't see why they say its a PCM problem, my only idea is that they know they screwed up on the rebuild and want more money before doing anything else.
2000 Rodeo LSE
Calmini 3" Suspension Lift Kit
Old 10-03-2006, 12:39 PM
Transmission started slipping, checked fluid and had enough, and within a few days (3) wouldn't shift at all.
Old 10-03-2006, 02:59 PM
Originally Posted by amigo-2k
uh oh ....
What's that ?? I don't understand Didn't hear/read a thing you said!
Holy shmoley - don't JINX me!!
jlpmba - have to agree, sounds like this transmission's slipping as well. Tell them to provide proof of the transmission swap - guessing you JUST had it done? They should be able to provide you - visually - with the old transmission as well as a warranty (??) for the new one?
FWIW - when your current tranny is fixed, make absolute certain to do partial fluid swaps every 15-20k, or full transmission fluid services EVERY 30k miles; do not go over 40k without swapping the fluid on these 4L30-E GM/Chevy transmissions, they hate old fluid and will break down sooner.
Also, you might want to check around for another transmission shop, not many will admit to the knowing of how to handle the 4L30-E transmission, which is currently obsolete and very difficult to work/rebuild on.
Good luck to you, keep us posted.
1997 3.2L V6 Rodeo
Old 10-03-2006, 07:07 PM
trooperbc's Avatar
trooperbc trooperbc is offline
Originally Posted by jlpmba
what do you all think?
check this post out and see if any of the symptoms are the same. it's about the mode switch and includes a lot of links i came on during my own research (including right back here).
link:
http://www.4x4wire.com/forums/showflat.php?Cat=&Board=UBB86&Number=902938&fpart= &PHPSESSID=
frankly, i'd go there first, if only because it's possible cause, and because it's easier and cheaper. but of course, you don't want to replace it without confirming and testing first.
let us know what you think after reading some...
hth
//bc
1992 trooper 3.2L v6 sohc automatic...as is
i love a good intermittent electrical challenge. . .especially when it's someone else's.
Old 10-03-2006, 08:03 PM
pharm_rodeo's Avatar
pharm_rodeo pharm_rodeo is offline
At what mileage after the rebuild did you start to notice the problem? Throwing any CE or CT lights? Did you ever drop the pan and change out the filter? What was the extent of the rebuild? They replace all soft parts and some hard parts? IF the tranny is STILL slipping after the rebuild, then it stands to reason they didn't do it correctly. I'm sure you got some sort of warranty?
1994 Acura Integra LS---212K+
1998 Isuzu Rodeo S 3.2L 2WD---176K+
Old 02-22-2007, 10:27 PM
iskiuskiweski's Avatar
iskiuskiweski iskiuskiweski is offline
Send a message via Yahoo to iskiuskiweski
when stopping.
all think?
I recently had this same problem and I wanted to share what I found. I had known for a while that my intake manifold gaskets needed to be replaced but it got pretty bad the other day, I could hear it sucking air, and the idle was pretty rough. The vacuum leak was enough to cause the tranny shifting problems, I am guessing this tranny has some kind of modulator connected into the vacuum system. I replaced the gaskets and all is well again.
98 Rodeo S/LS 3.2L V6 Auto 4WD 150k
Old 02-23-2007, 08:12 AM
srpope80 srpope80 is offline
Is your AC Fan blowing and turn lights working? I can't remember which one but one of those fuses controls the tranny shifting as well. I think it is the turn signals. I had a rear tailight wire get frayed and caused the fuse to blow and the tranny to shift like that; same symptoms.
