Recently I started my quest of fixing my horn. I first checked my fuses and took my airbag off. I didnt know what do with the airbag, i was just checking wires. so i went to i uncles shop and pulled the actual horn. upon installation i noticed it was simply unpluged. so with a quick snap at the harness, the horn was active and lound. Dones not trun off. it continously is blowing with out presing it. any suggestions. someone suggested a bad (AGH, I CAN'T THINK OF WHAT ITS CALLED, LIKE A FUSE BUT BIGGER.
Re: Horn
Check your BCM?
Body Control Module It has the relay that activates the horn.. Which year? http://www.autozone.com/servlet/UiBr...3d8015ec20.jsp
Bass 00' Park Ultra ![]() 94' Park Ultra 94' LeSabre 96' LeSabre
Re: Horn
Yeah, the relay is stuck shut. A new relay is about $10.
-Eric 89 LeSabre T-Type: CAI, STB, F41 Suspension, Moog Ball joints and tie rods, dual-out flowmaster and dual tips, Pointiac CD HU, Delco type 2 Ignition, etc. Basic H/C body info:http://www.3800power.bravehost.com/index.htm http://www.cardomain.com/ride/2318168 |
Re: Horn
A junker may be free... Im sure there are relays out there.
We have U-Pull it.. and U-Wrench it.. Wreck yards here. But.. $10 aint bad for the convenience. Might could whack the old one. Good Luck.
Re: Horn
Personally, I don't trust junkyard electronics.
my 1995 leabre.
Yesterday i tested further and found the problem to bee the swich above the airbag. looks like the only to fis is to discharge the airbag, or cut it open. i agaisnt that so my alternate solution is mointing new swich odd to the side of the horn. i already unpluged the wires under the horn and stuck them out to the side. if i touch the two wires together with a screwdriver, the work likes it supost to.
my 1995 leabre.
