Old 10-03-2006, 08:51 AM
taxidermist taxidermist is offline
Man trans swap
Will a 1993 metro manual trans swap into a 1996 metro with man trans?
Old 10-03-2006, 09:43 AM
idmetro idmetro is offline
Re: Man trans swap
taxidermist;
It'll fit just fine. There's lots of information in this forum that you can access by using the search function. Like all searches its dependent on what key words are entered but I think you'll find it informative reading just the same. I'm in the middle of replacing the 5 speed in my 94 right now. Good luck on your swap!
Old 10-03-2006, 11:19 AM
Crvett69's Avatar
Crvett69 Crvett69 is offline
Re: Man trans swap
it may fit just fine but gearing will probably be different. the 89-94 metros have 3 different ratios, the xfi is 3.89, the normal one is 4.10 and the convertible is 4.39. if yours is 3 cyl with 13" tires its 4.39, if its 4 cyl gearing may be as high as 3.50
Old 10-03-2006, 12:16 PM
Re: Man trans swap
This is the mother-in-laws car but i think it is the 4cyl how do I figure out what gears are in them?
Old 10-03-2006, 12:32 PM
Crvett69's Avatar
Re: Man trans swap
there is a transmission code on the drivers door sticker that will tell you what it is, with the code you can call the dealer to find out the ratio or go to teamswift.net. someone there had it posted a while back
