Go Back   Automotive Forums Car Chat > Dodge > Dakota
Old 10-03-2006, 05:46 AM
joevit joevit is offline
Oil pump
Can anyone tell me how to remove the oil pan so I can change my oil pump? Its a 2000 dakota w/ v6, 4wd. There doesn't seem to be enough room to get the pan down. Any help would be appreciated.
Old 10-03-2006, 08:31 AM
master hec0's Avatar
master hec0 master hec0 is offline
Send a message via MSN to master hec0
Re: Oil pump
enuf room? like ur doing this in ur back yard or somthing? if so u might need to lift it on some jacks for extra room
Crop circles are Chuck Norris way of telling the world that sometimes corn needs to lie the fuck down
The Great Wall of China was originally created to keep Chuck Norris out It failed miserably
A Handicapped parking sign does not signify that this spot is for handicapped people. It is actually in fact a warning that the spot belongs to Chuck Norris and that you will be handicapped if you park there
When the Boogeyman goes to sleep every night he checks his closet for Chuck Norris
Old 10-03-2006, 11:42 AM
Re: Oil pump
Yes I'm in my backyard and its on jacks. There doesn't seem to be enough room in between the oil pan and the front axle to manuver the pan down. Is there anyone who knows what to do?
Old 10-03-2006, 06:01 PM
Re: Oil pump
just get some mechanic to do it you might save some money vs tryin to get it out yourself
Old 10-04-2006, 06:18 AM
Re: Oil pump
It's ok if you don't know how to do the job, bud. Some of us like to do the job ourself. Now is there anyone else out there who can help.
Old 10-17-2006, 02:43 PM
rhandwor rhandwor is offline
Re: Oil pump
If you have an engine hoist hook up to the engine then unbolt the engine mounts and gradually pick up be careful and don't break anything. You can try a hydraulic jack under the harmonic balancer or under the front of the transmission. Auto zone may rent a hoist. Some people use a cable ratchet hooked to a tree.
You will need around 6 inchs of clearance. Sometimes you can get a wrench and your hand in and remove the strainer.
Be careful and don't get hurt I would rent a hoist.
Old 10-17-2006, 07:54 PM
Re: Oil pump
i rest my case
Old 10-19-2006, 10:19 AM
Re: Oil pump
Thanks rhandwor. I had to lower the front axle, raise the engine from the balancer. Then remove the starter and transmission to axle mounting bracket to get the flywheel cover off. The pan came right off after that. Oil pumped changed and screen cleaned and put back together. Thanks again.
Rest this masterhec0!
