Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 10-03-2006, 01:35 AM
NOFX0617's Avatar
NOFX0617 NOFX0617 is offline
Send a message via AIM to NOFX0617
Driveshaft Bearing
Alright...so I thought that my tranny was all jacked up because there is this stange noise that I started hearing a while back....you can only hear it when the car is under load and it also is speed related and not engine related...so I thought it was the tranny...but I drained the tranny fluid and there was nothing in it....it was freaking clean...and so I drained the transfer case and rear diff....and nothing in those either....so I want to say it is the driveshaft bearing aka the carrier bearing where the driveshaft connects to the transfer case...has anyone had to replace one of these before or had one go out on them...I am going to test my theory out this Wed. night...Any help would be appreciated as always
1998 Eclipse GSX
6 Bolt swap
MHI Big 16g
FP Race Manifold
Apex'i N1 Cat-back
Apex'i N1 Downpipe
Walbro 255 fuel pump
GReddy Type S BOV
Turbo XS Boost Controller
Balance Shaft Elimininator
ACT 2600
RRE 11lb No Name Flywheel
Prothane Motor Mounts
Tokico Illuminas Advanced Handling Kit
RRE Front and Rear strut tower bars
RMDSM Front and Rear Sway Bars
TRE Stage 2 Tranny
ARP Head Studs, Main Studs, Rod bolts
Old 10-04-2006, 09:13 PM
NOFX0617's Avatar
Re: Driveshaft Bearing
Anybody?
1998 Eclipse GSX
6 Bolt swap
MHI Big 16g
FP Race Manifold
Apex'i N1 Cat-back
Apex'i N1 Downpipe
GReddy Type S BOV
ACT 2600
TRE Stage 2 Tranny
