Old 10-02-2006, 10:11 PM
Jakeson Jakeson is offline
Question Awwww Nuts
2000 Taurus, with an impending need for drive axle service.
Nuts on front wheel spindles---we're needing a deep socket and the nuts appear to be 30 MM.
Question: Will a 1 3/16 inch deep socket fit?
Which socket should we get? Inquired mind needs to know. Thanks
Jake
Old 10-03-2006, 09:43 AM
TomV TomV is offline
Re: Awwww Nuts
30 mm = 1.181"
1 3/16" = 1.1875"
Depends on how tight your nut is and how much torque you need to apply to loosen it. The extra slop may not be a problem. You will have to make the call when you get the socket on the nut. I use a 30 mm and even that has some slop to it.
