Old 10-02-2006, 08:12 PM
miguel2112 miguel2112 is offline
87 f-150 shifter
The shift lever fell out of the steering column, does anyone know how to put it back, also the end of the lever doesn't appear to be sheared of inside the column.
Old 10-02-2006, 09:53 PM
unclebubbles unclebubbles is offline
Re: 87 f-150 shifter
If the lever came out in one piece, and didnt break, look around on the floorboard for the roll pin that holds it in place. It may still be in the hole in the column. There were a few years there that ford had a problem with them staying in. You should be able to stick the lever back in the hole, and gently wiggle it till it goes in place. Have a roll pin handy, or you can use a small bolt to get by if you cant find the pin. Once you get the lever back in the hole, stick a small screwdriver in the hole temporarily, and make sure it shifts ok, before you drive the roll pin in.
Every day we live, we`re one day closer to death. Learn to live, live to learn !
