Old 10-02-2006, 06:10 PM
maxassassin's Avatar
maxassassin maxassassin is offline
Send a message via AIM to maxassassin Send a message via MSN to maxassassin
sway bars
ok after consulting my manual and well the udner side of my car ive come to a stand still. does the 4th gen have a sway bar or is thta somethign else in the front.
06 cbr 600 f4i
91 civic hatchback.
96 nissan pathfinder
Old 10-02-2006, 06:33 PM
johnb16a2's Avatar
johnb16a2 johnb16a2 is offline
Re: sway bars
The front bar is near the rack and pinion. As far as I know all models except the standard model came with a front bar. GL
Old 10-02-2006, 07:35 PM
Re: sway bars
now that clears things up who makes a good replacement thats bigger.
06 cbr 600 f4i
91 civic hatchback.
Old 10-02-2006, 09:27 PM
FrodoGT's Avatar
FrodoGT FrodoGT is offline
Re: sway bars
The only one to come with a rear bar was the Si.
Cheap, Fast, Reliable..Pick two
Current project:
Rio Red 91 hatch.
A6/Z6 build, Hondata S300, Tokico illumina/Ground Control.
"I'd rather run 12's on steelies than 15's on rotas."
Old 10-02-2006, 10:58 PM
Re: sway bars
how do you put in a rear bar exactly. its is bolt on or drilling and tapping ect.
06 cbr 600 f4i
91 civic hatchback.
Old 10-02-2006, 11:47 PM
YZ125rider21's Avatar
YZ125rider21 YZ125rider21 is offline
Send a message via AIM to YZ125rider21 Send a message via Yahoo to YZ125rider21
Re: sway bars
it bolts on...only way to go is suspenion techniques!!! you only need the rear bar and summitracing.com sells them individual for our cars....after market front bar is not needed
90 Honda CRX Si
-Red/Black
-B20B/b16
-AEM CAI -/\- Apexi GT Header/2¼" Custom Dynomax Exhaust
-Tein SS CoilOvers with pillow ball monuts -/\- ST Swaybars/Energy Suspension Bushings
-16x7 Lightweight Rotas -/\- Pro Stop Rotors -/\- Goodridge S.S. Brake Lines
-Skunk2 Shifter -/\- MoMo Steering Wheel
Old 10-03-2006, 07:00 AM
BLU CIVIC's Avatar
BLU CIVIC BLU CIVIC is offline
調整器
Send a message via MSN to BLU CIVIC Send a message via Yahoo to BLU CIVIC
Re: sway bars
but if he has a standard an Si sway bar is just as good for a lower price
The name's Adrian
1990 Civic HB Si - 265.7whp/223tq @9.2psi. Tuned on NepTune by J.Mills
1991 Civic Sedan DX - 296.3whp/230tq @1bar. Tuned on NepTune by J.Mills
1991 Civic Sedan DX - 185.8whp/139tq. Tuned on NepTune by J.Mills
2006 G35 Coupe 6MT - Stock
2011 CR-Z - Stock
Old 10-03-2006, 04:57 PM
Tony's Avatar
Tony Tony is offline
TLD Member #1
Send a message via AIM to Tony
Re: sway bars
Thanks for answering that on the rear sway bar. I was pretty sure the Si came with a rear one since there are spots for the bar to bolt up on the body. I was going to try using the lower control arms off a DA to put on on, but that doesn't work. You can get it to fit but its a PITA and I don't know for sure how it will work going down the road.
Tony
91 Civic Sedan DX - Stock 287k Miles
Old 10-03-2006, 06:08 PM
TheSilentChamber's Avatar
TheSilentChamber TheSilentChamber is offline
Forunn Daberator
Re: sway bars
So you've tested all that are available, compaired them scientifically, tested them in differnt environments and surfaces and driving styles and type? Or did you type that because thats what you have?
Old 10-03-2006, 07:08 PM
Re: sway bars
I have front and back...wish I had stock front bar but did I tell him to get a front bar too cause I have front????I dont think so....I dont post much here anymore cause some of you arent much help...my facts are from honda-tech and if you like I be happy to search for the thread but you have to give me some time cause I cant sit by a computer all day long to respond back so quickly
90 Honda CRX Si
-Red/Black
-B20B/b16
Old 10-03-2006, 07:42 PM
Re: sway bars
well wha tever works really i jsut want a slightly upgraded sway bar. but ive also kdian got a different topic i now wanan tal kabotu and thats "suspension sag". im a big guy i na lwoered honda and well it kidna unuusally dips to the driver side. what besides my weig hwill cause this.
06 cbr 600 f4i
91 civic hatchback.
Old 10-03-2006, 07:48 PM
Forunn Daberator
Re: sway bars
Are fat fingers the reason your typing is all over the place?
Well having X more amount of weight on one side is naturally going to make that side sit lower, you can use adjustable coilovers to cross weight you car- with you in it, and while your driving it would sit level- but finding a shop to do this may be hard.
Old 10-03-2006, 08:43 PM
hondacivic99sivtec's Avatar
hondacivic99sivtec hondacivic99sivtec is offline
Send a message via Yahoo to hondacivic99sivtec
Re: sway bars
you might be missing a bolt in the front suspenion some where. mine was doing the same thing. sagging on the drivers side. i only 125 so i know it wasn't me. i was missing a bolt on my control arm. it made the whole car lean.
-tony-
2000 honda s2000
Old 10-03-2006, 09:10 PM
Re: sway bars
no fat finger wouldnt be the reason why i type so shitty it would be the fact that i dont care as much as msot of you. and i dont have coilover. i have tein coils now. and im nto missing any hardwear. but i also do kidna need an alignment.
06 cbr 600 f4i
91 civic hatchback.
Old 10-08-2006, 10:59 PM
StockCRXSI's Avatar
StockCRXSI StockCRXSI is offline
Re: sway bars
If you go with a rear, make sure it comes with the proper mounting brackets.
'03 600RR - Jardine slip-on, FE, Scotts Damper. For sale!
'95 Civic hatch b20/itr RPF1 ksports etc etc
'92 Civic 4dr - daily - Yakima rack, Prokit, RPF1
'08 Big Sur - single track
