Old 10-02-2006, 04:11 PM
cowboyili cowboyili is offline
Power Steering Pump Replacement
I have a 98 Grand Prix GTP and I need to replace the power steering pump. I plan on picking one up on the way home from work, but I was wondering how difficult it is and if anyone had any tips/advice before hand.
Thanks!
Old 10-02-2006, 05:38 PM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: Power Steering Pump Replacement
Here's the power steering pump replacement procedure for a GM car equipped with a Series II 3800 engine to include getting air out of the system. Click view answer. Good luck!
Make sure engine is cold. Disconnect battery negative cable. You'll need a droplight to see what you're doing.
Remove strut tower cross brace, if installed.
Remove the coolant reservoir. If you have a Grand Prix with one mounted on the passenger side strut tower, remove it.
Remove the serpentine drive belt by loosening belt tensioner.
At this point, I highly recommend jacking up the passenger side of the car and removing the tire. Support with a jackstand. Remove the plastic splash guard. This will make getting to the pressure and return lines easier.
Remove the 2 power steering pump mounting bolts. Size = 15mm. The bolts holding the PS pump are in the 12 o’clock and 6 o’clock positions. You'll need to move the PS pulley and line up the large access hole in the PS pump pulley with the bolts. Once lined up, using a deep well socket remove them.
Remove pressure and return lines from PS pump. The pressure line is on the bottom of the pump itself and has a metal fitting. The return line is attached to the reservoir and is just a piece of tubing with a hose clamp on it. Remove pump. The pump will start leaking fluid all over the place once the lines are disconnected. Try to tie the two lines up, if possible, so that they don't fall over and start pouring out fluid.
The new pump may or may not come with a pulley and reservoir. If not you will have to transfer them from the old pump to the new one. The replacement should come with directions on how to do this but you will probably need a gear/pulley puller to get the pulley off the old pump.
Install new PS pump. Attach the pressure and return lines to the new pump. Re-mount PS pump by replacing the 2 bolts and tightening (20 ft-lbs).
Re-install plastic splash guard. Re-install tire (lug nut torque=100ft-lbs) and drop back to ground level.
Re-install the serpentine belt. This may be a good time to install a new belt.
Re-install coolant reservoir, if applicable.
Re-install strut tower cross brace.
Make sure everything is tight and properly torqued.
Re-connect battery negative cable.
Refill and air bleeding procedure (rack n pinion system):
NOTE: To relieve steering tension when engine is off, you can raise and support the vehicle with front wheels off the ground. Use good quality power steering fluid. A small funnel with a long hose attached should be used to add fluid.
With ignition off and in steering unlock position, turn wheel to the left. Now add power steering fluid to the FULL COLD mark on the dipstick. Leave the cap off. Turns wheels side to side several times without hitting the steering stops. Check fluid level again and add to maintain level at FULL COLD mark.
Start the engine and let idle for approximately 5 minutes. Turn the wheels all the way to the left and right several times without hitting the stops. Turn off engine and check the fluid level again. Make sure that it is at or near the FULL HOT line. Replace cap.
Road test car and then check for leaks. Also you can re-check fluid level again just to verify.
Timeslip 08/12/06
AF Community Guidelines
Old 10-05-2006, 11:51 AM
i installed the new power steering pump last night. what a pain in the ass. i noticed my ABS light on and my LOW TRAC light on today. I'm assuming I need to check the electrical connections again? Do you know of any other causes that would make the lights go on besides a disconnected electrical connection?
Old 10-05-2006, 12:19 PM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
A defective hub bearing will cause those lights to come on if the wiring is fine. The ABS wheel speed sensor is part of the hub, and cannot be replaced separately. I had the wire coming out the hub bearing break on my 99 GT and fixed it by re-soldering and covering with liquid electrical tape.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 10-05-2006, 12:50 PM
BNaylor's Avatar
If you did not have the problem before the PS pump job then it will be related to the work performed. Since that wiring harness that goes to the passenger side hub/wheel sensor just happens to be in the way while doing that type of work on the power steering pump then I would check the electrical connector first then carefully inspect the wiring as it runs along the lower control arm and to the ABS modulator. That plastic wiring covering really doesn't do a good job of protecting the wiring.
Timeslip 08/12/06
