Go Back   Automotive Forums Car Chat > Nissan > 240Z | 260Z| 280Z | 300ZX (Past Z Cars)
240Z | 260Z| 280Z | 300ZX (Past Z Cars) The original Z cars - ones that started it all.
Old 10-02-2006, 03:44 PM
Ultra Violet Ultra Violet is offline
Over heating?
Ok so i am talking to a friend of mine who used to own a 1992 N/A 300zx about if he knows anyone who has one up for sale. He says puzzled " why do you want one of them " i tell him its a beautiful car i would love to start on a tuner that will make eyes pop ! lol he says " the Vg30s are shit , with cooling . mine i had to run a bigger cooling kit and better fans when i got to about 450 hp ."
so are they really that bad with over heating ?
also from what i remeber when i was younger my mom had a 1990 N/A 300zx and the dealer told us to get rid of the thing before 90k . sure enough at around 80k miles it started knocking alot !
If anyone can through in some insite to this that would rock
Old 10-02-2006, 04:19 PM
1viadrft's Avatar
1viadrft 1viadrft is offline
Re: Over heating?
Your friend had an NA Z32 making 450HP? That's a load of crap... he lied to you about his HP. ask him for a dyno sheet next time you see him. As far as over-heating??? Even highly modified-well maintained NA Z32's are still using the stock radiator or a slighly bigger Maxima radiator.
I have only had one time where my NA Z32 overheated (and I live in the desert) and that was because my heater hoses were busting and I was loosing coolant. Bigger radiators are not necessary on a VG30DE. Just plain ol' maintenance. Electric fans would be great to free up some power though.
Maintenance is the main key for the Z32 and all cars for that matter. My NA Z32 is running close to 125K miles and is still running strong.
1990 Z32 2+2 BLITZ SUS Intake, HKS ALC
My 1994 TT Supra For Sale: http://www.automotiveforums.com/vbul...d.php?t=623105
Old 10-02-2006, 04:37 PM
DeleriousZ's Avatar
DeleriousZ DeleriousZ is offline
Send a message via MSN to DeleriousZ
Re: Over heating?
i think your buddy needs a good kick in the balls for thinking that he's making 450hp on an n/a vg30...
ZedEx Crew Member #6
1988 300zx turbo 5spd. 3" mandrel exhaust, filter, afco rad, e-fan, poly engine mounts, mbc at 8.5 psi, turboxs rfl-h bov, gutted plenum, etc.
blown turbo, under construction.. gt35 coming.
Old 10-02-2006, 07:03 PM
Eclipsewhipping Eclipsewhipping is offline
Re: Over heating?
The dealer just wanted to sell your mom another car. i know many Z's turbo and N/A that are running smoothley at well over100k
Old 10-03-2006, 07:15 AM
Re: Over heating?
AHH i wouldn't think he is lieing because he just finished his 3 year projects on his Civic he drop a k20 bullet proof running 9.0.1 with a t70 turbo and he is hitting in the range of 750hp @ 20 PSI he isn't done dyno testing but i seen the sheets for that . needless to say he isn't talk talk talk . i have seen picture of it and all the work he does on his cars in the past. but another thing . does it make a differents if the injectors are top or side? what year did it change over?
Old 10-03-2006, 11:29 AM
k3smostwanted's Avatar
k3smostwanted k3smostwanted is offline
Z Cars Fanatic
Send a message via AIM to k3smostwanted
Re: Over heating?
overheating is not really an issue with the VG. they run fairly cool and have no trouble staying at a decent temperature as long as everything in the cooling system is working properly and you upgrade the radiator at the proper time in the path of modifying. do NOT put an electric fan on a TT until they have been proven to keep things cool. as of right now, nobody has designed an electric fan kit for the VG that is as effective or more effective than the stock clutch fan and shroud set-up.
on the other hand, heat is an issue...but not overheating, temperature in the engine bay get really hot due to the lack of room and lack of venting in the hood. this just amounts in the wiring harness not lasting decades and premature sensor failure.
ZedEx Crew Member #4
Old 10-03-2006, 11:54 AM
Re: Over heating?
Ok i can live with that then
Old 10-03-2006, 01:49 PM
doberman_52's Avatar
doberman_52 doberman_52 is offline
Send a message via MSN to doberman_52
Re: Over heating?
The only time that i have ever seen one come close to overheating is after a motor swap and we screwed up a brand new thermostat.otherwise when a friend screwed his up when runing like 20 -30 psi and fried the rings, now when he does 90 for a little bit his gets pretty warm and thats a 95 turbo
Old 10-03-2006, 01:56 PM
DeleriousZ's Avatar
Re: Over heating?
he's running on a fried engine? that's kind of silly...
Old 10-03-2006, 02:22 PM
Z Cars Fanatic
Re: Over heating?
let me guess...that 20-30psi was on pump fuel and stock turbos too.
Old 10-03-2006, 03:12 PM
1viadrft's Avatar
Re: Over heating?
I'm still calling BS...
What mods does he have?
Old 10-03-2006, 06:35 PM
Re: Over heating?
I met the him/ chris about 3 years ago right after the got rid of it and it was a beautiful car he even did sund cmps with it and he ran high 10s with it also i seen the picture of that to. but doesn't matter ! main thing i would like to know what are the main problems to exspect from the Z32s so i can get right on them
Old 10-03-2006, 11:43 PM
Re: Over heating?
He is parting it out aoon but doesnt have a lot of money, i would guess that is why he runs it with fried rings, stupid, but works for him. I'm sure it was pump gas and most of his parts are stock so I would guess they were stock turbos, that is actually an 85 turbo not a 95, he is also now in college, another money issue.
Old 10-04-2006, 12:01 AM
DeleriousZ's Avatar
Re: Over heating?
wow he must REALLY be poor if he can't fix up a z31 lol.... poor car doesn't deserve a fate like that
Old 10-04-2006, 01:45 AM
Z Cars Fanatic
Re: Over heating?
wow...20-30psi on a stock T25 Z31 turbo. i don't even think it will flow that much air but reguardless, talk about out of efficiency.
