Old 10-02-2006, 11:58 AM
Boiler_guy22 Boiler_guy22 is offline
Send a message via AIM to Boiler_guy22 Send a message via Yahoo to Boiler_guy22
Brake drag
I had to replace the rear pads this weekend because they were down to the warning bar. After replacing the pads I noticed I could hear the brakes dragging while I was driving, its not real bad but its enough to notice and to heat up my brakes. Any suggestions? I don't see any leaks at the master cylinder and the brakes feel good, they just don't completely release.
Old 10-02-2006, 06:15 PM
Blazer SS Blazer SS is offline
Re: Brake drag
Did you re grease your pins? Please make sure that you have completely blead your rear breaks.
Old 10-02-2006, 06:21 PM
alblogg's Avatar
alblogg alblogg is offline
Re: Brake drag
Yep might need to check them out before you glaze or crack them new pads.You can spend the time cleaning the pins if they are rusty or corrode or buy a new set and get some white lithium grease and put some where they slide not a whole tub just enough to keep metal from metal.
'99 Blazer LT Loaded, K&N Filter, Pioneer Super
Tuner,Viper
'98 Pontiac Grand Prix GT, 3.8
'88 K1500 Cheyenne, 5.0, stock, bought new
'86 Nissan 720 Trash Truck
'69 C/10 step side, 307, all original, second owner, in process of restore.
The person who says it cannot be done should not interrurt the person doing it.
Share your knowledge. It is a way to achieve immortality.
Allen- Paintman
Wrenchtwister
Broompusher
Old 10-02-2006, 07:00 PM
muddog321 muddog321 is offline
AF -Advisor
Re: Brake drag
Looks like a 99 so 98up have single piston rear calipers that once you push them back in most always cock or jam in the bore so I always replace with rebuilts and as stated pull the rubber boots and pins out of the bracket and make sure they slide freely. For others - but "loaded" calipers with a rebuilt caliper, pins, bracket, and disc pads - best way to go.
Old 10-02-2006, 07:04 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: Brake drag
Did you completely push the cylinder back into the caliper?
If you don't push them all the way back then they won't release fully.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 10-02-2006, 09:39 PM
Re: Brake drag
Thanks for all the help all. I think someone has already said this but its a 99 4X4 with 4 wheel disc brakes, the calipers have a single piston. I did grease the rear caliper pins. I have yet to change the pads on the front. The reason I noticed the problem at all was that I ate through the pads on the back. At first I thought that it was just time to change the pads. It was only after I changed the back pads that I noticed the front brakes were heating up too. Is it pretty common to have all the calipers need grease at once? Maybe I should just pull the calipers on the front and grease the pins before I go much further, the rear brakes seem fine now. No one votes for master cylinder problems? What about the antilock brake system? I'm new to antilocks. My 1972 pickup didn't have them.
Thanks again.
Old 10-14-2006, 02:48 AM
1996LTOwner 1996LTOwner is offline
Re: Brake drag
My '96 rear brakes were dragging and ate up the shoes. Found the E-brake cable housing had rusted through and would not allow the cable to fully release. Had to replace the cable.
