Old 10-02-2006, 11:44 AM
rsatter22 rsatter22 is offline
Fuel pressure spec
Does anyone know what the fuel pressure range should be for a 1999 5.3L?
Thanks- Rick
Old 10-02-2006, 01:59 PM
GMMerlin's Avatar
GMMerlin GMMerlin is offline
I know stuff
Re: Fuel pressure spec
379-427 kPa (55-62 psi)
Why do you never have enough time or money to do the job right the first time, but enough time and money to do it again?
Got all the certifications
25 years ASE Certified Master Technician
GM WCT
Yea..I work at a DEALERSHIP....got a problem with that?
Want to diagnose cars like the Pros? FOR SALE: OTC Perception 2 channel Labscope (badged as a Matco Reality)
This is my personal labscope that I use to diagnose waveforms, like new, comes with leads and training video
PM Me for details
Old 10-03-2006, 11:15 AM
Thank you.
Old 10-03-2006, 08:49 PM
Well looks like it is the pump- pressure bouncing between 49 and 53 and now the pump is whining. I understand there are 2 models of the fuel pump that were used. Something about a pump code "TCU" or "TCF". Is there a way to identify which pump is on mine before I pull it out of the tank? I'd like to purchase it before I tear it down.
Thanks- Rick
Old 10-04-2006, 05:29 AM
Rmbodie's Avatar
Rmbodie Rmbodie is offline
Is the difference because of flex fuel or tank size ? Rob
2000 Trans Am six speed Blackbird .Fast enough stock!
2005 Grand Prix.
2005 2500HD Silverado 4x4 , Duramax!!!!!!! Lifted ,Pumped,Humped,Thumped!
1988 JEEP Cherokee: Lifted, Sons new toy.
Old 10-24-2012, 07:37 AM
PsychGen's Avatar
PsychGen PsychGen is offline
Bumping old thread as it appears no one ever answered the question. TCF= vehicle equipped with evaporative emissions, two electrical connectors at fuel tank module, one connects to the BLACK pressure sensor mounted to tank module. TCU= no evaporative emissions, single electrical connector, no pressure sensor.
Old 10-24-2012, 03:40 PM
j cAT j cAT is offline
I am quite sure this has been figured out since it has been 6 yrs past now that this was asked.
before buying these type parts best use the vehicles vin number to be sure the correct electrical parts are used. this would also cause the updated electrical parts are correct for the vehicle. these pumps have been redesigned since build date on most models.
in the USA most regions if not all require this vapor emission recovery system,....
Old 10-24-2012, 06:29 PM
PsychGen's Avatar
I spent over half a day looking for what the differences in the two units were, thinking that someone on this forum would be kind enough to mention that after changing their fuel pump. While changing one I was faced with a unit that had no T-Code. Yes, Five post on this forum speak of codes TCF and TCU but neither of them explain the actual differences. For your convenience I shall list them: This one you are reading, http://www.automotiveforums.com/vbul...hlight=tcf+tcu, http://www.automotiveforums.com/vbul...hlight=tcf+tcu, http://www.automotiveforums.com/vbul...hlight=tcf+tcu, http://www.automotiveforums.com/vbul...hlight=tcf+tcu Neither of the a fore mentioned posts make any mention of the differences in the units. Only what the different units are used for. There are many of these trucks still on the road, many will be needing fuel pumps and parts stores are still asking the dumb TCF or TCU question instead of asking does it have a pressure sensor in the module and one or two wiring connectors. So I posted this here so future Chevy truck owners would get their question answered.
Old 11-10-2012, 02:57 PM
to get the correct fuel parts for your vehicle you must use the vin #.
there are too many changes. even some part stores will mess this up.
the dealership will give you the correct part number . then you can use that number for part cross reference.
regulator and pumps are what is the issue .
Old 11-10-2012, 03:39 PM
PsychGen's Avatar
Being a shop owner and subscriber to Autozone Pro and M.O.R.E. OEM, I'm well aware of the value of the VIN#. However, even entering the VIN# both sites ask for the 'code'. I'm just trying to help you DIYers out as there are still many of these vehicles on the road today, many still on the original pump. Parts houses are still asking the same dumb question. Asking if the vehicle has evaporative emissions makes more sense than asking for a code that one must remove the fuel pump to access. Evaporative Emissions can be determined from the Vehicle Emissions Control Information label affixed somewhere in the vehicles engine compartment.
Old 11-11-2012, 07:24 AM
being from OK do you have any emission laws in that state ?
