Old 09-03-2002, 12:37 PM
FourthGenHatch's Avatar
FourthGenHatch FourthGenHatch is offline
Send a message via AIM to FourthGenHatch
Who here with a Civic has rear disc?
I am going to do a 90-93 Integra Rear Trailing Arm swap and I was wondering if anyone here did it also?
http://www.fourthgenhatch.com
FOR SALE: Get this stuff out of my house!
-Stock hood (red) $30
-Stock Rear Spoiler (red) $30
-Stock mirrors $30/both
-Stock side front and rear side glass $30/piece
Old 09-03-2002, 12:56 PM
dfarres's Avatar
dfarres dfarres is offline
Send a message via Yahoo to dfarres
I havent done it but Here's a site with instructions.
1993 Civic Coupe EX
1997 Chevy Suburban LT
“It's all fun and games - Until someone loses an eye"
Old 09-03-2002, 01:19 PM
GTA's Avatar
GTA GTA is offline
Whee..
EF_LSVtec has the rear disc swap, he said it was pretty easy just take the old one off and bolt the new one in. I forget what car he got em off thouh...
AF Bay Area Crew
RIP Melt
2008 Mitsubishi Lancer Evolution GSR
2007 Toyota Prius
I <3 and miss my 4g
Old 09-03-2002, 01:44 PM
TrailerParkJake TrailerParkJake is offline
Send a message via Yahoo to TrailerParkJake
i have it done on mine. the toughest part is running the ebrake cables through that damn rubber grommet that goes into the interior
Old 09-03-2002, 03:50 PM
BigBearWest's Avatar
BigBearWest BigBearWest is offline
WWW.CalgarysFinest.COM
Send a message via ICQ to BigBearWest Send a message via AIM to BigBearWest Send a message via MSN to BigBearWest
what e brake cables do u use? the integra ones?
Old 09-03-2002, 07:29 PM
EF_LSVtec's Avatar
EF_LSVtec EF_LSVtec is offline
Send a message via AIM to EF_LSVtec
trailerparkjake is right, running the ebrake cable is the toughest part...next to bleeding. I used 91 teg rear arms and reused brake lines, ebrake cable and replaced rotors and brake pads.:flash:
AF Bay Area Crew
Fully Built LSVtec Motor (245.8 whp/164.6 torque)
88 DX Hatch to JDM SiR conversion
Retired SOLD 1/08
Licensed Mortgage Consultant (Calif.)
Cellular 415.699.1797
Old 09-03-2002, 07:44 PM
gunnmen01's Avatar
gunnmen01 gunnmen01 is offline
Send a message via AIM to gunnmen01 Send a message via Yahoo to gunnmen01
I swapped rear trailing arms from a 92 ls onto my hatch. You'll need the integra e brake cables. I've done 2 rr. disc brake swaps now, they only get easier, count on 4 or 5 hours to do the swap the first time.It's also a good time to replace struts or add springs or coil over, slotted rotors etc. etc. etc. Get a good manual to help you through it andyou shouldnt have a problem...
gunnmen01
My other ride..... is YOUR MOM !!!!!!
Old 09-03-2002, 08:21 PM
just use the teg ebrake cables, but the brackets that mount it to the chassis need some "modifications" to work right. either that or dont use them
Old 09-03-2002, 09:09 PM
I'm rebuilding these Trailing Arms with Energy Suspension Poly Bushings, Brembo Rotors, Goodridge SS Brake Lines, and new Honda Pads. So while they are already off the car it will be much easier.
I've done work on the rear suspension and it's not hard, already put in new shocks/struts and Anti-Sway Bar.
Old 09-05-2002, 09:09 AM
obsidian66 obsidian66 is offline
If i get S.S Brake Lines for a 89 civic will they fit the integra trailing arms?
Old 09-09-2002, 12:40 AM
1990civic's Avatar
1990civic 1990civic is offline
whats the going price for the 93 integra trailing arms?? i think i can get them for 150 bucks should i go for it??
thanks
Old 09-09-2002, 12:57 AM
EF_LSVtec's Avatar
They usually go for $75-100 each side.
AF Bay Area Crew
Retired SOLD 1/08
Old 09-14-2002, 11:55 AM
johnnym's Avatar
johnnym johnnym is offline
I have done the swap and you got my trailing arm from a 92 teg. The swap does widen the rear track slightly so if you plan on having a really slammed ride make sure you have the correct offset. I have +38 offset and it rubs way too much. had to even raise it up to almost stock height beacuse of the rubbing. So if you have an offset of +40 +42 and have the fenders tucked you should be fine... And that link earlier on this make to the how-to was done by me. Enjoy...
Old 09-14-2002, 11:35 PM
1990civic's Avatar
hey JOHNNYM for sure you will know what you are talking about!! which e-brake cables should i go with?? can i use the ones already on my hatchback?? or should i just go with the teg cables??
Old 09-15-2002, 10:34 AM
Yes you use the ebrake cables for the 90-93 Teg.
As for them sticking out I don't think thats true. I read a site that gave the lengths of all the Civic and Teg parts and though they are different they come out to be the same total lenght. Maybe you switched more than just the trailing arms because I heard that will mess up things.
How to take out a rear side window from a 96 honda civic Danthony_20 '96-'00 Civic 1 11-05-2009 10:38 PM
00 Civic EX Rear Disc Conversion ??? mattcivic Wheels/Tires/Suspension 1 05-09-2006 11:05 PM
00 Civic EX Rear Disc Conversion mattcivic '96-'00 Civic 1 03-06-2006 05:48 PM
Will 92 Civic SI rear discs fit 92 CX? AirbagsOnDaHonda Wheels/Tires/Suspension 12 06-19-2004 04:32 PM
Who here has a 2001 and/or up Civic? nspunich '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 0 12-10-2003 02:46 AM
