Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 10-02-2006, 12:51 AM
96eclipsegsx06 96eclipsegsx06 is offline
wire hanging down
when changing my drive belts on my eclipse gsx i noticed a wire hanging down from the alternator. there is another wire just like it but it is connected to something else. I cannot seem to find where the wire plugs into. please help any ideas will be helpful
1996 eclipse gsx
Old 10-02-2006, 09:00 AM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Re: wire hanging down
Don't know. A pic would be nice. If it works fine, you really don't need to worry about it. Was the alternator replaced? Is it connected to the alt?
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 10-02-2006, 10:28 AM
the wire is coming from the alternator. the alternator was not replaced but the drive belt going around the alternaot came off when the crankshaft pulley broke. thats when i noticed the wire. i have not started up my car since friday and i noticed the wire on saturday.
Old 10-03-2006, 02:18 AM
SLoe's Avatar
SLoe SLoe is offline
96 GST 5 spd.......(R.I.P.) smashed by a fallen tree
2001 Camaro SS 6 speed goodness!
Old 10-04-2006, 02:55 AM
caniborrow50cnts's Avatar
caniborrow50cnts caniborrow50cnts is offline
Send a message via AIM to caniborrow50cnts
the only wires i can think of in that area would be the oil pressure switch, alternator to battery wire, 2 negative wires for alt, and the power steering pump. o2 sensor is there also but cant be hanging down, unless its been cut.
either your oil pressure gauge doesnt move, or your alternator light will come on. the wire off the ps wont do anything.
72 Beetle - trashed
88 Escort EXP - dumped
92 Talon - sold
97 Eclipse RS - still own
99 Eclipse GST - still tearing up the asphalt
Old 10-04-2006, 09:23 AM
nofear39427 nofear39427 is offline
Send a message via Yahoo to nofear39427
I remember my 91 did the same thing and I found a wire hanging.I looked and looked and finally found that it plugged into a little nipple on the alternator.Maybe its a ground of some sort.Good luck
Old 10-04-2006, 03:10 PM
Black99GST's Avatar
Black99GST Black99GST is offline
Send a message via AIM to Black99GST
Originally Posted by loeman
Old 10-17-2006, 06:34 PM
TeamRedLine23's Avatar
TeamRedLine23 TeamRedLine23 is offline
Send a message via AIM to TeamRedLine23
actually, the little black wire that runs from the alt. plugs onto to a liitle nipple on the power steering pump. if that wire is not grounded the car will run like shit, not much but enough to notice a difference.
1997 Eclipse GS-T
Performance modification:-evo3 16g-K&N Intake-HKS SSQV b.o.v vented-2.5'' Dejon tool blow thru upper and lower-Dejon large smic-GM MAF-MAF Translator-HKS 3" Carbon Fiber Titanium TBE-stock fuel rail-Walbro 190 fuel pump-PE 650cc injectors-Accel Thundersport wires-NGK series 7 spark plugs-1g intake mani/head-
Interior Modification:-Autometer Boost Gauge
http://www.cardomain.com/id/xTeamRedLine23x
