Go Back   Automotive Forums Car Chat > Volkswagen > Passat > '97+
Old 10-01-2006, 09:43 PM
bcopeland bcopeland is offline
VW Passat stumbles while driving
I have a 99 VW Passat that stumbles while driving. It usually happens while we are slowing down or speeding up, but it does happen while crusing at 65 - 70 MPH. We replaced the fuel pump, the spark plugs and the valve cover gaskets. It may run fine, then start to stumble like the classic fuel pump failure. Can you help?
Old 10-04-2006, 09:57 PM
veedubmechanic's Avatar
veedubmechanic veedubmechanic is offline
VDUBMAN
Re: VW Passat stumbles while driving
what engine and trans do you have?
Old 10-05-2006, 09:47 AM
It is a V6 2.8 with a 5 speed automatic transmission.
Old 10-06-2006, 12:03 PM
Will12 Will12 is offline
I have 1.8T, had similar problem. It came up to be the air intake came off. Check if you have the air intake tight and nothing is there--change air filter too.
Old 10-08-2006, 10:33 PM
VDUBMAN
I dont usually see drivability issues with V6. How many miles do you have, a worn stretched timing belt can cause driveability issues with no check engine light. It should be replaced every 90-100k miles.
Old 10-10-2006, 11:25 AM
It had about 75K. It only does the stumble occasionally. Usually when it is started for the first time for the day, it runs great. It seems to have this problem after 30 minutes or so. Can a timing belt make it behave like this?
Old 10-20-2006, 04:35 PM
VDUBMAN
I would reccomend a tune up and fuel filter
Old 10-30-2006, 10:34 AM
I had the timing belt changed and the spark plug wires changed. It runs good now except that it smokes. The mechanic said there was a ball bearing on the block that was crimped on and it was leaking.
Old 11-08-2006, 12:04 PM
VDUBMAN
There is a water pump thats runs off the timing belt, they commonly leak coolant and if it Was leaking i dont know why the shop wouldnt have said anything because to replace to needto remove the timing belt
Old 11-09-2006, 05:03 PM
Sorry - I meant an oil eak. It seems to be leaking onto a tailpipe or something.
Old 11-10-2006, 07:09 AM
Where does it smokes from: tail pipe or engine compartment?
Also, I am not familiar with mechanics of vw engine, but there should be a rotary seal on any bearing connected to the body that keeps an oil in the engine.
Old 11-14-2006, 10:24 PM
It was smoking from the engine compartment. At first a lot then a little. NOW, the automatic headlights do not work, the turn signals do not work, the AC won't blow. Seems like either the dimmer switch, the light switch or a relay. Maybe that is what I smelled - a relay burning.
Old 11-17-2006, 01:17 PM
VDUBMAN
vw has LOTS of problems with valve cover gaskets and cam seals especially on v6 engines! they tend to leak onto the catalytic converter.. and smoke alot
