Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 10-01-2006, 10:35 PM
lyricfoto lyricfoto is offline
Send a message via AIM to lyricfoto
2000 Rodeo, 3.2 idle air control/CEL/tranny
Ok, I have been having the IAC issues, dying on start, then high idle at times. I have seen many posts on this, however, my 2000 rodeo does not seem to have the IAC on the throttle body as many other posts indicate. I called a dealer to inquire about the part, and they said something about an idle air or idle speed sensor, which apparently lives inside the throttle body...any help?
I also have my CEL on intermittently, once every few weeks it will come on for a few hours to a day or so. The code read random misfire in one or more cylinders. The thing is, the Rodeo doesn't run any differently when the light is on than when it's off, which is why i have kind of ignored it. The first time, i changed all the plugs, but that was it. Could the IAC/something similar be the culprit?
This SUv has also had a rebuilt tranny in the last year, which now has a slow seepng leak which two different shops have been able to fix properly. The most recent Aamco put in new pan gaskets, but the seepage began after a month or so.
Any help is greatly appreciated!
Thanks!!
Old 10-02-2006, 12:26 AM
amigo-2k amigo-2k is offline
Isuzu Guy
Re: 2000 Rodeo, 3.2 idle air control/CEL/tranny
Miss fires and idle issue usually point to a bad intake manifold gasket.
There is one common place for a tranny leak see the FAQ's for more info.
-Ryan
Isuzu Moderator
Car Show Tips
Operations manager with a results-driven passion for process improvement
FAQ 98-04 Isuzu Rodeo, Rodeo Sport, Amigo, Trooper
SOLD - NOV2015 - 2000 Amigo, V6, HT winter, ST summer, 2wd
Old 10-02-2006, 06:31 AM
rodeo02 rodeo02 is offline
Originally Posted by lyricfoto
... I have seen many posts on this, however, my 2000 rodeo does not seem to have the IAC on the throttle body as many other posts indicate...
Where did you see posts that indicate this? It's a well documented fact that 2000+ 3.2/3.5's use electronic throttle control (throttle by wire). This system uses no IAC. Idle speed is controlled by the ECM. Like Ryan says, your problem probably stems from a vacuum leak caused by a bad IMG.
Joel
2016 Subaru Forester 2.5i base CVT
2016 Nissan Quest SV
Old 10-02-2006, 01:52 PM
Thanks for the suggestions. today i found the leak on the tranny (shifter seal) and replaced, hopefully that will take care of that.
Also had the codes read again: random misfires, and air speed sensor low voltage. hopefully this a simpe sensor issue (the one on the intake).
pardon my ignorance, looking through many posts about the IAC, didn't find very many that specifically mentioned 2000 3.2 throttle by wire.
Old 10-04-2006, 09:42 PM
Isuzu Guy
btt.
I knew I read this before.....
-Ryan
Isuzu Moderator
Car Show Tips
