Go Back   Automotive Forums Car Chat > Oldsmobile > Eighty Eight
Eighty Eight Includes the '97-'98 Regency and '96-'99 LSS Models
Old 10-01-2006, 09:18 PM
madawaska madawaska is offline
95 olds 88 electrical problem
The car was working fine, then quit. Now the door locks, windows, power seats and fuel pump are not working.
Old 10-01-2006, 09:37 PM
acidcrashdburnd's Avatar
acidcrashdburnd acidcrashdburnd is offline
Send a message via AIM to acidcrashdburnd
Re: 95 olds 88 electrical problem
oh boy thats wow vats system maybe but i dont think that would mess with the windows and locks ill check into this for you :-/
1993 Olds 88 112k and counting 81 mile a day daily driver.
2005 Grand Prix 47k weekend car.
Old 10-02-2006, 03:35 PM
Mickey#1 Mickey#1 is offline
I'd bet a paycheck that it's your grounds. There are two (one on each side)ground busses that are located under the carpeting near the door sills. You need to pull the metal bar from the connector and clean both the bar & contacts inside the connector. Put some dielectric grease on the contacts & bar before reassembling. Here's a link to a thread that has some good pictures of the ground buss. Check both sides!http://www.bonnevilleclub.com/forum/...er=asc&start=0
Old 10-02-2006, 07:33 PM
I pulled the ground bus bars and yes the one on the drivers side was melted from corrosion! I cut all the wires off and soldered them together, now it starts and everything works. I kinda thought it was a ground problem because all the fuses and relays were good, but I couldn't find the common ground point for the fuel pump, windows, door locks, power seat, etc. Thanks, you just saved me a tow and probably a lot of money to boot.
Old 10-02-2006, 08:53 PM
Glad it worked. Good idea just soldering them together.
