Old 10-01-2006, 07:52 PM
sammy91182 sammy91182 is offline
Wink 2004 Grand Prix GTP starting problems
This only happens occasionally - Have a problem sometimes when i go to start the car, it will sound like it is starting but it doesn't turn over. I usually hit the gas while turning the key and then it starts. Any ideas?
Old 10-02-2006, 07:32 AM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: Grand Prix starting problems
Although the data is in your profile in limited form, it would be helpful to list the year, model, engine size and mileage in the post.
Timeslip 08/12/06
AF Community Guidelines
Old 10-04-2006, 07:52 PM
I have a 2004 Pontiac Grand Prix GTP - with 57000 miles and it has a 6 cylinder engine.
Old 10-07-2006, 02:18 AM
04GTP-WhatLAG?'s Avatar
04GTP-WhatLAG? 04GTP-WhatLAG? is offline
Re: 2004 Grand Prix GTP starting problems
you may want to clean the injectors(try GM fuel addictive), check the spark plugs and wires first little things like that... If it is cold in your area, it is NORMAL... the reason is the PCM is in cold start mode which is where the car is pretty much choked, as it warms up the PCM goes out of this mode... I will say that it is very important to let your car warm up before driving off...
if I was guessing I would say it is the injectors needing cleaned or a really cold environment...
Custom K&N Fenderwell Intake , 180° thermostat, 3" Down Pipe, High Flow Cat, DHP 1.0 PCM, 3.5" pulley, 1.9 Ratio Roller Rockers, 90# LS6 Valve Springs, AL104s, ZZP Motor Mounts, 17" American Eagle 192s, Magnaflow tips.
not just babies whine
