Go Back   Automotive Forums Car Chat > Ford > Mustang > Mustang Problem Diagnosis
Mustang Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 10-01-2006, 10:24 AM
dst69 dst69 is offline
1969 Mustang when braking car pulls to left?
Hi,
Over the past 14 years I've rebuilt this car from the ground up...entire new brake system too. It recently started to pull to left when braking. Tires are new and balanced. I don't drive the car very much maybe 15 miles a month in the warmer months only. The car has manual brakes with drums all around.
Any thoughts?
thank you
dt in NJ
Old 10-01-2006, 09:10 PM
eggfarmer eggfarmer is offline
Re: 1969 Mustang when braking car pulls to left?
Lets start with a bleed job. Possibly right side wheel cylinder stuck. Or go ahead pull drums and get an eyeball at the shoes. Might jut be a simple adjustment required.
Old 10-02-2006, 06:43 AM
72' Stang 351 H/O's Avatar
72' Stang 351 H/O 72' Stang 351 H/O is offline
It sounds like you tightend one of the brakes on more than the other.
Old 10-02-2006, 12:30 PM
KimMG KimMG is offline
AF - Advisor
Did you replace the flex lines? Old, internally deteriorated hoses can cause uneven braking. Take a look at the shoes to see if you have uneven wear from one side of the car to the other.
