Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse 2000+
Old 10-01-2006, 01:37 AM
pimpendacavi06 pimpendacavi06 is offline
tail light install
i have takn a breif look behind the backing of the taillights and i sonly see a bolt and two bulbs is there any special trick to getting the taillights off and on i just bought a new set and it would be nice if someone could help me out..thanks in advance
Old 10-01-2006, 02:42 AM
brad02420's Avatar
brad02420 brad02420 is offline
Re: tail light install
I have 4 bolts holding mine on, I have heard that 03-05 only have 3 bolts but I'm not sure as to how true that is. Just look at the back of the tail lights you bought and that will give you an idea as to where the bolts are. There is no trick just unbolt and pull like hell and dont forget to unclip your lights.
North Star White 2000 Eclipse GT 5 Speed.
Mods-Greddy EvoII Exhaust System,Injen Cold Air Intake,Megan Racing Short Shifter,ES Shifter Bushings,Greddy Counter Weighted Shift Knob, Fidanza Lightweight Flywheel, Prothane Motor and Trans Mounts,Clear Corner Lights,APC Euro Tail Lights,Mio C520 GPS,Passport X50 Radar Detector,Sony Xplode HU.
Old 10-01-2006, 02:59 AM
rodbls's Avatar
rodbls rodbls is offline
Send a message via AIM to rodbls
Dont "pull like hell" unless you are certain you have all the nuts taken off. Some of them are almost impossible to get to, especially to tighten. If you drop a nut....dont try and get it because it's gone...never to be seen again. You really have to get your hand in there to get to a couple of them. No trick, just Gumby hands.
2000 Fed. Spec GT-"Lafawnduh"
Mods: SPEC 2+ Clutch, Fidanza Flywheel, PowerStop Rotors, Red Stuff Pads, Stainless Brake Lines, B&M Short Shifter, Energy Suspension Shifter Bushings, Deyeme Firm Motor Mounts, KYB AGX shocks with Eibach Proline springs, Halo Projector Headlights with HID 12000K Conversion, TYC Carbon Tails, Kicker SS6.5 Component Front, SS MB8 Custom rear, Tsunami 2F Capacitor, ***New Stuff*** JVC KD-AV7010 In Dash DVD Player, Kicker L7 12" Woofer, Kenwood KAC-X10D Mono Amp
Old 10-01-2006, 03:15 AM
brad02420's Avatar
LMAO I dropped a nut and took about all the plastic pieces out to try and get it. I finally was able to hit it with a screw driver and knock it down to my spare tire, I was so pissed. So yeah be carefull about dropping things down in it and yes also make sure you take all the nuts off. My taillights where a pain to get off after all the nuts where out is why I said to pull like hell. I think I was able to get to 3 of the nuts with a socket wrench and had to use a open wrench on one but I have long and skinny hands.
Old 10-01-2006, 10:12 PM
Sleepr awd's Avatar
Sleepr awd Sleepr awd is offline
Send a message via AIM to Sleepr awd Send a message via Yahoo to Sleepr awd
long skinny hands are a must. i have very long hands
but seriously, taking all the panels off makes it incredibly easier and you'll be able to see exactly what you are doing with every one of the bolts.
if you don't... well... you'll figure it out.
musthave for any butterfingers: magnetic telescope
Don't act like you don't love it.
503/2000
