Go Back   Automotive Forums .com Car Chat > Ford > Mustang > Mustang Problem Diagnosis
Mustang Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 10-01-2006, 02:25 AM   #1
acidcrashdburnd
acidcrashdburnd's Avatar
Send a message via AIM to acidcrashdburnd
03 GT engine sucked water now knocking
all right my g/f's brother drove his car threw high water and to no surprise it stalled out.. we changed the oil on the side of the road and filter it ran fine for about a minute then it started taping a loud taping its just sitting at there house right now i told him not to drive it the tap is on the right side of the engine closest to the firewall im just trying to figure out how water would of got into the engine the water didnt only went up to the bottom of the doors any help would be appreciated being hes at a lost and im a supercharged 3.8 oldsmobile driver i know nothing about mustangs :-/
sorry for any spelling or grammatical errors as im bit tired
1993 Olds 88 112k and counting 81 mile a day daily driver.
2005 Grand Prix 47k weekend car.
acidcrashdburnd is offline   Reply With Quote
Old 10-01-2006, 05:13 PM   #2
acidcrashdburnd
Re: 03 GT engine sucked water now knocking
help?
Old 10-01-2006, 10:15 PM   #3
eggfarmer
tapping or knocking? Water could of seeped thru one of the lower seals (not likely). The noise has to be determined.
eggfarmer is offline   Reply With Quote
Old 10-01-2006, 10:26 PM   #4
acidcrashdburnd
its a tapping noise it coming from the top of the engine on the right side closest to the firewall
sorry i dont know much about these engines im gona take the cover off tomorrow and try to pin point the tap
Old 10-02-2006, 07:43 AM   #5
72' Stang 351 H/O
72' Stang 351 H/O's Avatar
Water might have go into the cylinder, when it fired it might have broke a rod. Not likely, does it have power issues?
72' Stang 351 H/O is offline   Reply With Quote
Old 10-02-2006, 01:36 PM   #6
KimMG
AF - Advisor
Did you check the air intake to see if it was wet? With all the moving parts, water can splash up pretty high in the engine compartment. Check the ignition system, you may have a cylinder that is not firing. Do you have a check engine light on?
KimMG is offline   Reply With Quote
Old 10-02-2006, 05:39 PM   #7
eggfarmer
sounds like a lifter might have collapsed. Pull valve cover and confirm.
Old 10-02-2006, 10:41 PM   #8
acidcrashdburnd
there is no ses light im gona pull the cover tomorrow to check it how do i tell if there is a collapsed lifter?
Old 10-02-2006, 10:42 PM   #9
acidcrashdburnd
and its more of a knock then a tap i guess i could say i will find out tomorrow
Old 10-02-2006, 11:21 PM   #10
eggfarmer
there will be more "play" in the pushrod.
Old 10-03-2006, 10:20 AM   #11
6speed
6speed's Avatar
this is a modular engine, what pushrod?
i think you should visit www.corral.net or www.modulardepot.com techincal boards they will be able to offer more advice.
07 jeep cherokee srt8
99 saleen s281
05 cbr 1000rr
6speed is offline   Reply With Quote
Old 10-03-2006, 07:14 PM   #12
eggfarmer
well, that shows my age and why I should keep up with technology. I did not even know what a modular engine was. Looked it up though and educated myself. Saw a nice cross-section of a cyl. head. Just amazing!!! If the noise is coming from the top as stated, you should be able to use a stethascope and hear the location. Hope you did'nt bend a valve.
Old 11-17-2006, 12:23 PM   #13
ahnial8u
ahnial8u's Avatar
This happned to my 94 GT
About 3 mins later it threw a rod right through the side of the block!!!
ahnial8u is offline   Reply With Quote
Old 01-20-2007, 07:47 AM   #14
modrich
Check all of the sparkplugs and coil packs and make sure all of them are firing. Also see what the plugs look like.
modrich is offline   Reply With Quote
