Go Back   Automotive Forums Car Chat > Ford > Expedition
Old 09-30-2006, 10:36 PM
BackNine29's Avatar
BackNine29 BackNine29 is offline
'00 Expendition -- Noisy Window Mechanism
2000 Expedition EB Model. Driver window noisy upon roll down/roll up. May be dirt. Not sure. How to to check or clean?
Thanks,
BackNine29
Old 10-05-2006, 07:05 AM
JoeShmoe's Avatar
JoeShmoe JoeShmoe is offline
Send a message via AIM to JoeShmoe
Re: '00 Expendition -- Noisy Window Mechanism
I don't know how to check but you remove the panel yourself. Take the cover off the top right cover held in place by plastic pins. Next pull the side mirror control up from the panel and disconnect the wire harness. Remove the plastic lamp cover with the red reflector at the bottom of the door by poping it off from the bottom with a flat head screw driver and removing the two screws. After that you pull the bottom of the door panel away from the door to loosen it up. Once it's loose pull up on the door handle and it should slide right off, sorry coouldn't be any more help, Good Luck.
