Old 09-30-2006, 10:24 PM
loulit loulit is offline
abs light on, speedometer not working, not shifting
i have a 98 chevy blazer. abs light is on speedometer sometimes works , sometimes does not. truck doesnt shift out of first gear. sometimes the speedometer will just pop on while driving abs light goes off and truck drives fine. pulled out fuse to abs still have same problem. help!!! check wheel speed sensors all connections are good .
Old 10-04-2006, 08:32 PM
Blazerboy1287's Avatar
Blazerboy1287 Blazerboy1287 is offline
Send a message via AIM to Blazerboy1287 Send a message via MSN to Blazerboy1287
Re: abs light on, speedometer not working, not shifting
You may have checked the connections, but did you check to make sure that the wheel speed sensor is functioning properly?
Black 1995 Blazer LT 4 Door 4x4 *SOLD*
@110000 miles
3-inch piping with a Flo-Pro V-Force Muffler
97 Eclipse GST (Burgundy) (powered mostly by Ebay)
123000 miles
Short throw Shifter
Ebay true 3-Inch Stainless Steel Catback
Ebay Intake w/ K&N filter
GSX dual piston upgrade
Powerslot Rotors
Akebono Ceramic pads
All synthetic fluids
"It is only after you have lost everything that you are free to do anything."
-Tyler Durden
Old 10-04-2006, 08:54 PM
blazes9395's Avatar
blazes9395 blazes9395 is offline
Newbie mod
Sounds like a VSS sensor (vehicle speed sensor) going bad, or loose connection. It will usually give you the problems you exactly describe.
