Go Back   Automotive Forums Car Chat > Buick > Riviera
Old 09-30-2006, 07:43 PM
DINO55's Avatar
DINO55 DINO55 is offline
Exclamation Headlights Keep Shuting Off...HELP!
Hello Riviera expert's,
My friends 1996 Riviera's Headlights will shut off at will, then turn back on. The tail lights seem to stay on while this is happening. Can anyone tell me if this is a common problem with Riv's and where I might be starting to look for the fix? Also is there a headlight relay for this car and where might it be? The Buick dealer want's $490.00 for a new headlight dash switch ( yikes)...
Any help on this will be Appreciated Greatly...
Thanks, Dino
1998 BLAZER LS Vin-W 4Dr 2wd
2004 Cavalier LS 4Dr 2.2 Ecotec
"Good Part's ain't Cheap--Cheap Parts ain't Good"
Old 09-30-2006, 11:29 PM
96riviera18 96riviera18 is offline
Re: Headlights Keep Shuting Off...HELP!
its not a problem i have heard of b4, since it is a 96 it has the 2, iirc, sensors on the dash for automatic lights at night. i would try covering them with something dark to see if they stay on. there could be a fuse in the engine bay, either by the one by the air box or the one by the passenger headlight. if not then there is a fuse box on the door panel (driver side) and a bunch of fuse boxes under the rear seat. it sounds like a loose wire in the switch. good luck
matt
