Old 09-30-2006, 06:37 PM
ase2009 ase2009 is offline
1985 tranny or clutch problems
when i drop the clutch in 1st and then shift to second the engine revs but doesn't show any increse in speed but if i let off a lil it will catch and then go is it my clutch needing replacing or tranny? 1985 chevy s10 1.9l 4 banger
Old 09-30-2006, 07:38 PM
JustSayGo JustSayGo is offline
Send a message via AIM to JustSayGo Send a message via Skype™ to JustSayGo
Re: 1985 tranny or clutch problems
The clutch... and rear crankshaft, or front trans seal if either is leaking oil. Do you have freeplay at the top of clutch pedal travel?
Old 10-01-2006, 09:07 AM
yes there is free play in the clutch pedal about inch and a half of play and the throw out bearing makes that squeeling noise if i dont tap and hold it a lil bit while im driving.
Old 10-01-2006, 11:01 AM
Deffinatly time to replace your clutch. Manual transmissions can not slip.
Old 10-01-2006, 12:35 PM
thank you very much for ur help man appreciate it.
