Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 09-30-2006, 04:56 PM
97GSTspyder's Avatar
97GSTspyder 97GSTspyder is offline
Send a message via AIM to 97GSTspyder
Ignition problem?
Haven't been on here in a while been kinda busy lately...Anyway since i never updated my sig, here's whats up.
97 GST hardtop
5spd
16g turbo (small)
Slowboy FMIC
NGK plugs
K&N FIPK
10.4mm wires
Hallman boost controller
Greddy Type S
ACT 2100
B&M Short throw
And new pics of the car - for you MySpace freaks. - http://profile.myspace.com/index.cfm...endid=14406566
Here's the problem. A while ago, if i tried running 15+ psi, the car would start to sputter real bad. Of course, I tried fixing the complicated shit first. Turned out being my plugs. They were improperly gapped at .035 because when i first gapped them, i used a feeler gauge because i couldn't find my gapper lol...Anyway they're gapped at .028 now. I can run 17psi fine now, and it pulls like a champ. But here's the new problem. Anything over 17psi, the car starts to sputter like before. I'm not getting fuel cut. Yes I'm still on the stock fuel system and i know i'm getting close to maxing it out, but i was told by someone at the track that i should be able to run 19-20 with the stock fuel system. Is that true? And why is my car sputtering? Are the injectors starting to cut out but not completely?
Old 09-30-2006, 05:42 PM
wanaplay134 wanaplay134 is offline
Send a message via AIM to wanaplay134
Re: Ignition problem?
i dont know about your injectors cutting out when i first finished my talon i could run 22 lbs before i hit fuel cut. when you hit fuel cut you will know it for sure. did you check for any leaks maybe you should do a compression test.
but it could very well be your fuel system i mean the last time i seen you your car had what 130,000 miles it could be time to replace that old ass fuel pump of yours you can run those injectors for a while just get a 190.
but i really dont know what else to say that just sounds like a wierd problem
1992 eagle talon tsi awd
xtd stage 3 six puck/apexi 3' downpipe and exhaust/ngk plugs/taylor thunderbolt wires/manual boost controller set at 20psi/walbro 255 with rewire/autometer boost gauge/turbo xs rfl blow off valve/arp headstuds/ to4b vtrim turbo/dnp tubular manifold with o2 housing and tial 38mm wastegate/eagle rods/ross pistons/acl bearings/arp rod bolts/arp main studs/aeromotive fuel pressure regulator and all stainless lines/aem fuel rail/slowboy street front mount kit
