Old 09-30-2006, 11:59 AM
94_3.4 94_3.4 is offline
manifold problems
i just replaced the intake manifold on my 94 3.4 camaro, and now it wont run right. im wondering if there is a fuel problem since i had to take the fuel rail out to replace the manifold. i know that the gasket is seated properly, and all of the vacuum lines are in place. is there any procedure i have to follow to repressurize the fuel system? i dont kneed to prime the fuel rail or anything do i? the engine vibrates horribly at idle, and has almost no power while driving, and the entire car shudders when i step on the gas. its almost as though the car were running lean. please help!
Old 09-30-2006, 02:09 PM
Nate355RS's Avatar
Nate355RS Nate355RS is offline
Re: manifold problems
Those simptoms kinda sound like a spark plug wire is arcing, or one that's not completely on the plug. Check to see if one of them isn't on all the way or if one is burnt through. I know the plugs aren't related to the manifold, and if everything is ok with them than that's one thing you can rule out. Why did you have to replace the intake manifold?
'91 RS, forged LT1, GTP heads, blower cam, AFR Hydra-Rev kit, ram air intake, SLP 1 3/4 headers and 3" y-pipe, 3" Dynomax exaust, Yank 2800 TT stall converter, Strange 3.73 gears with Zexel-Torsen LSD, ect, ect...
Old 09-30-2006, 03:24 PM
blindeyed's Avatar
blindeyed blindeyed is offline
eBay aDdict™
Send a message via AIM to blindeyed
Do you mind me asking why you had to change the intake manifold to begin with?
- Jason
1995 Pontiac Firebird
User Guidelines | VB Codes Explained | AF Merchandise
"Each of us, is in the scheme of things, insignificant.
But millions of insignificant people, doing a tiny bit,
can add up to be a very significant force."
Old 09-30-2006, 11:39 PM
i just replaced the wires today, as i was thinking on the same lines as you. no change in the condition, though i still havent gotten around to pull the plugs themselves, or checking out the coil packs. i also noticed a small vacuum leak today that i hope to have fixed by tomorrow. i had to replace the manifold because the old one was cracked near the throttle body, and the tension on the throttle body bolts finally broke a large chunk off.
Old 10-01-2006, 12:03 AM
corning_d3 corning_d3 is offline
Send a message via Yahoo to corning_d3
You didn't cross-wire it, did you?
2007 Certified DaimlerChrysler Service Technician...
True blue GM at heart.
Old 10-01-2006, 12:51 AM
no, all the wires are on the right plugs...
Old 10-01-2006, 01:34 AM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Sounds like a vacuum leak. Double check to ensure the correct gaskets were properly installed.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 10-01-2006, 09:40 AM
its the right gasket, and it did go on right. i did find a vacuum leak yesterday but i havent gotten out to the store to buy a new part yet should be done today... ill let you know
Old 10-01-2006, 10:09 AM
ahh... found the problem (i hope!). after reading a thread on another forum, i decided to check all the fuses pertaining to the ignition system, and stumbled over a blown fuel injector fuse. should have it fixed within the hour. thanks for all the help!
Old 10-02-2006, 11:33 PM
I'd make sure a injector wire wasn't pinched somewhere. They very rarely blow for no reason..
