Old 09-30-2006, 11:48 AM
jenn331 jenn331 is offline
power seat issues
my 2000 blazer lt driverside power seat does not work but the lumbar works is this a wiring problem? and if it is wher should i start?
Old 09-30-2006, 04:37 PM
muddog321 muddog321 is offline
AF -Advisor
Re: power seat issues
Check the fuses. Lumbar and heater are 1 fuse and the rest is another and a relay also I believe. Look in the owners manual - it shows which are which and if in the door fuse panel or underhood.
Old 10-26-2006, 06:18 AM
rcandgirls rcandgirls is offline
Send a message via MSN to rcandgirls Send a message via Yahoo to rcandgirls
Exactly the same problem. Lumbar works, other 2 switches don't. Operators manual does not show fuses for power seats either in dash or under hood but all fuses in both boxes are okay. I've seen other posts on this issue where the owner had the memory feature (I don't) and it was resolved by disconnecting the battery for 1 minute and reconnecting and the relay must have reset and solved the proble. hamlinhazel had mechanic find short in wire under backseat requiring removal of seat. How have others resolved ?
Old 02-17-2007, 10:59 AM
problem solve under the carpet had to remove seats and replace a section of wire.water got under the carpet.i think the water got in from the trim on the floor by the door be cause the clips come through the body and are only held in by 2 sided tape
Old 02-17-2007, 06:10 PM
ericn1300's Avatar
ericn1300 ericn1300 is offline
AF Premium User
a classic problem in these vehicles, if you're having problems with the power seats, address it immediatley. there have been numerous reports of seats catching on fire from wiring problems even with the ignition off. there should have been a recall, in my opinion.
