Go Back   Automotive Forums Car Chat > Toyota > Tacoma
Old 09-30-2006, 11:43 AM
morrisonnc morrisonnc is offline
Power Steering Pump Installation
I am installing a Cardone power steering pump in a 2004 Toyota Tacoma. The Cardone installation guide says "to carefully remove pressure fitting from replacement pump. Do not allow valve and spring to drop out of the pump. Does the 2004 Toyota Tacoma have a pressure fitting, valve and spring or is this for the reservoir? If the truck has the pressure fitting, valve and spring, what is it and where is it?
Old 10-08-2006, 12:23 PM
Flash75 Flash75 is offline
AF - Advisor
Re: Power Steering Pump Installation
Here is a link to the 2003 shop manual. It should have the information you need for power steering pump replacement. Go to Volume II. then to the SR section for power steering pump repair and repalcement.
http://www.deserted1.com/FSM/
Clifton
