Go Back   Automotive Forums Car Chat > Volkswagen > Jetta/Vento/Bora > '83 - '90
Old 09-30-2006, 12:23 PM
JunkTitleGolf's Avatar
JunkTitleGolf JunkTitleGolf is offline
Brother got an 87 Wolfsburg Jetta...trouble starting
Ok the previous owner told him that the fuel resovior had a hole in it. So we repaired the spot. Went to start it and it won't turn over. We checked the fuel pump fuse and it was fine. the resovior isn't back on yet. Could that be a problem?
1995 VW Golf
Cold Air Intake
Cat delete
Full straight pipe exhaust
4 gauge big 3
Pioneer head unit
Power Acoustik Amp
Cerwin Vega Vmax sub
Old 09-30-2006, 02:24 PM
Re: Brother got an 87 Wolfsburg Jetta...trouble starting
Resovior is back on and still no luck to getting it to start. Any other possibilities? There is also a sound of compression in the engine bay area. Like it blow back out of a spark plug.
1995 VW Golf
Cold Air Intake
Cat delete
4 gauge big 3
Pioneer head unit
Power Acoustik Amp
Old 10-13-2006, 02:52 PM
Doug Tatham Doug Tatham is offline
I'd check your compression on your cylinders. If you have a problem there, you need to really start looking. You may have a lot of air in your fuel lines. Remove the ignition wire from your starter and turn the key for a bit to circulate the gas. Check your fuel pressure to see if you're getting fuel. Check for vacuum leaks. After that, do the standard: check spark, check airflow, check fuel. Try to track where the blow back sound is coming from. Your exhaust may be leaking, which can lead to death.
