Go Back   Automotive Forums Car Chat > Ford > Explorer | Explorer Sport Trac
Old 09-30-2006, 11:00 AM
nmpitbull nmpitbull is offline
instrument cluster problems
the gas guage doesnt light up and the light switch doesnt light up all the fuses are fine what could this be ?
Old 09-30-2006, 01:59 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: instrument cluster problems
Have you checked the illumination bulbs for the fuel guage and for the light switch?
-Rod
Old 09-30-2006, 02:10 PM
where are the illumination bulbs located?
Old 09-30-2006, 11:31 PM
shorod's Avatar
SHO No Mo
What year is your Explorer? Specifics may vary from year-to-year.
The bulb for the headlight switch will be accessed once the swtich assembly is removed from the dash. There will likely be a small plug like round plastic piece with a slot in the center. Use a flat blade screwdriver to turn the "plug" 1/4 to 1/2 turn counterclockwise. Once it comes to the stop, then pull the plug out. The bulb will be installed in this plug.
The bulb for the fuel guage will be installed in the instrument cluster and you will most likely need to pull the instrument cluster to access it. The bulb will be installed in a similar fashion to the headlight switch, but at a larger scale.
-Rod
