Go Back   Automotive Forums Car Chat > Dodge > Neon | Plymouth Neon > 1st Gen 95-99
Old 09-30-2006, 10:22 AM
nmpitbull nmpitbull is offline
cranks no start
my 96 neon cranks but doent start the battery, alternator, and starter are all good i dont get spark and i dont know what it could be can someone help me please
Old 09-30-2006, 04:04 PM
das2123 das2123 is offline
Tuning Neons since '97
Send a message via AIM to das2123 Send a message via Yahoo to das2123
Re: cranks no start
Make sure all your connections are clean and secure. The neon is very sensitive to corrosion.
2003 Dodge SRT-4
Old 09-30-2006, 05:14 PM
Re: cranks no start
all the connections are good and tight and where they are supposed to be
Old 09-30-2006, 07:12 PM
Re: cranks no start
Did you have the battery and alternator checked? Have you checked for fuel pressure at the rail?
2003 Dodge SRT-4
Old 10-01-2006, 03:29 PM
Re: cranks no start
yea and it has fuel pressure
Old 10-01-2006, 04:42 PM
Re: cranks no start
How much? I think it should be around 44psi.
2003 Dodge SRT-4
Old 10-01-2006, 05:31 PM
skatendestroy skatendestroy is offline
Send a message via AIM to skatendestroy
Re: cranks no start
i think its 48
Old 10-01-2006, 07:19 PM
Re: cranks no start
Just checked my FSM and it says 49psi for my 97.
2003 Dodge SRT-4
Old 10-02-2006, 10:33 AM
Re: cranks no start
i got 47 psi
Old 10-02-2006, 10:49 AM
Re: cranks no start
OK, it cranks but doesn't start, right? Do you hear the fuel pump prime? Is the starter engaging but just not turning over? Make sure your battery is fully charged. If you keep trying to crank it and it doesn't, it will drain the battery. Will it start with a jump?
2003 Dodge SRT-4
Old 02-10-2007, 07:28 PM
96jimmy4wd 96jimmy4wd is offline
Re: cranks no start
if you are not getting spark, check the coil pack first on the harness going into it you should have 12v at the center wire this is a common hot that feeds the coil and the fuel injectors the other two wires should be a ground signal from the computer if it does not pulse a ground while cranking the next step is to check the crank sensor (rear of engine jst above oil filter) look for 8v-9v @ the orange wire and as the engine rotates, the grey wire should send back a ref voltage of about .5v to about 5v next is the pcm hope you dont get this far $$$
some people are like slinkies....
they aren't good for much, but they are fun to push down stairs
