Old 09-30-2006, 10:20 AM
offroadjoe offroadjoe is offline
rpm gauge
hey guys i got a 88 sierra and my buddie just gave me his rpm gauge its got a shift light and everything but i was wondering if anyone had a link or could tell me how to install one its got four wires green/red/white and black but i no what black is lolol so if anyone knows how to wire one up please tell me thanks guys
Old 09-30-2006, 10:54 AM
777stickman 777stickman is offline
Re: rpm gauge
I'm pretty sure your '88 has an HEI type distributor. So the Green wire would go the the Tach terminal on the dist, Red wire to a keyed ignition source,
white wire to an instrument panel light source and Black wire to ground.
57 Chevy 210
65 Olds 442 Convertible (Another one sold)
75 GMC Vandura 3/4 Ton
1999 K2500 Old Body Style Suburban (Gone but not forgotten)
05 Dodge Ram 3500/5.9 Cummins
2012 Toyota FJ Cruiser
Old 10-01-2006, 08:44 AM
chrisk1500 chrisk1500 is offline
Re: rpm gauge
There is a wire beside the coil that should not be connected to anything....it has a male spade connector on it....IIRC the wire is white.....connect your tach lead to this wire....
94 Silverado 1500 Z71, 320 000 kms, 6.5 TD (VIN S), 3.73 rear, 4L80-E, high idle switch, snorkel removed, EGR blocked off with 45mm frost plug in tower, ISSPRO boost gauge and pyrometer (pre-turbo), #9 resistor, FSD cooler remote mounted behind bumper, 6' homemade PMD extension harness, 97 cooling upgrades, 10k pot set @ 10 psi boost, gutted upper intake, WAP glow plugs, leaf spring helpers....Saving up for: straight pipe 4" exhaust, intercooler, chip...
Old 10-02-2006, 05:04 PM
Re: rpm gauge
ok i might be mistaken but is the Tach terminal my cluster? my truck dosnt come with a rmp gauge so i would need to hook it up somewhere to my coil? i'm lost lol HELp!! thank you lol
Old 10-02-2006, 05:08 PM
Re: rpm gauge
you guys think there a wire diagram on the wed?
Old 10-02-2006, 05:28 PM
alblogg's Avatar
alblogg alblogg is offline
Re: rpm gauge
You will not hook it to your tach terminal in your dash you will have to wire it like these guys told you. The green wire you run out under the hood and hook it to the white wire chrisk says coming from the coil with a male spade on it. Hook the red wire to a source that is only hot when the key is turned on. The white wire to one of the dash lites for illumination and the black wire to a good body ground.
'99 Blazer LT Loaded, K&N Filter, Pioneer Super
Tuner,Viper
'98 Pontiac Grand Prix GT, 3.8
'88 K1500 Cheyenne, 5.0, stock, bought new
'86 Nissan 720 Trash Truck
'69 C/10 step side, 307, all original, second owner, in process of restore.
The person who says it cannot be done should not interrurt the person doing it.
Share your knowledge. It is a way to achieve immortality.
Allen- Paintman
Wrenchtwister
Broompusher
Old 10-02-2006, 08:20 PM
Re: rpm gauge
Even better is to connect your white wire from the tach to the fuse labeled 'instrument panel' and your tach light will dim with your dash lights.....
Old 10-03-2006, 03:33 PM
Re: rpm gauge
ok i found my coil and theres two wires goin into it.... and theres two wires comming out of it going to the distributor.. now i'm guessing i have to attach the green wire on my rpm gauge to the white wire thats coming out of the coil and into my distributor? and when i mean attach i mean cut and just join it right?
Old 10-03-2006, 03:51 PM
Re: rpm gauge
alright well i hooked up the wire for the coil and its all working but i still need to hook up the white wire to the dimmer switch i donno where to find the wore or how to hook it up
Old 10-03-2006, 05:32 PM
fuzzypuppy's Avatar
fuzzypuppy fuzzypuppy is offline
Re: rpm gauge
I hooked all of my after market gauges to the hot wire that comes out of my dimmer switch, use a test light till you find the one that dim's with the switch, that way your dash and gauges will be lit the same.
Old 10-03-2006, 08:57 PM
Re: rpm gauge
Maybe you didn't read this well enough....
Old 10-04-2006, 12:54 PM
Re: rpm gauge
lol i got it all hooked up.. pretty sick as soon as i found out where my coil was it was all good thanks guys...
