Go Back   Automotive Forums Car Chat > Toyota > 4Runner/GX470
Old 09-30-2006, 08:56 AM
patriot88 patriot88 is offline
Fog light short
I installed hella foglights that installed into the factory harness. They worked for a while and now as soon as I turn them on, I blow a fuse. I disconnected the pass.side light and replaced the fuse and it worked. So I know I have a short between the pass. side light and the relay (since the drivers side will work.).
What is the easiest way to fix this issue?
I was thinking of running a separate line, splicing back into the original wires at the harness and at the relay. Or could it be a harness issue? I have no idea where to begin, size of wire or if its even possible. Any ideas?
Old 09-30-2006, 11:23 PM
KimMG KimMG is offline
AF - Advisor
Re: Fog light short
You are going to have to physically check the wire for damage.
Old 10-01-2006, 12:07 AM
corning_d3 corning_d3 is offline
Send a message via Yahoo to corning_d3
Re: Fog light short
I agree. If you find no problem in the wires, pull the light out and make sure the wires aren't shorting inside the light housing.
2007 Certified DaimlerChrysler Service Technician...
True blue GM at heart.
