Go Back   Automotive Forums Car Chat > Chevrolet > Nova
Old 09-30-2006, 01:09 AM
nikkistarr nikkistarr is offline
Stock Motors
Did the 454 come stock in the Nova? (If no, what did other than the 350) and if yes, what years?
Wide Open Throttle
Old 09-30-2006, 05:59 PM
stompin60 stompin60 is offline
Re: Stock Motors
here are some of the years and engines
http://www.novashop.net/info/engines.htm
1991 Trooper 2.8 yes it is red, and yes I have had the tranny rebuilt
Old 10-01-2006, 08:20 PM
Re: Stock Motors
Hey thanks, that's good info. Great website. Thanks again.
Wide Open Throttle
Old 10-02-2006, 02:49 PM
AlmostStock's Avatar
AlmostStock AlmostStock is offline
Re: Stock Motors
Wasn't it really something that in 68, 69 and 70 the same car was available with a 4 cylinder motor, two versions of the 6 cylinder, three or four versions of the small block V-8 and two of the big block V-8? Include the several transmission choices (at LEAST four each year) and we had more power train options than we are likely to ever see again.
If only I could perfect that time machine...
Mark's Garage est. 1983
Old 10-02-2006, 10:17 PM
Re: Stock Motors
You seem like you know a lot about the Nova. Want to share any info.? I plan on buying one. My favorite year was the 74. For no particular reason except the body style. Your perfect Nova would have what motor and what powertrain?
Wide Open Throttle
Old 10-04-2006, 09:45 PM
Re: Stock Motors
I own a 74 Nova (L-48 350), which I couldn't pass up because it only had 14,XXX miles on it when I found it with the original owner. 73 and 74 had the larger crash bumpers and lower factory HP (compared to 68-72) which makes them slightly less desirable, and SHOULD be able to be found at a slightly lower cost.
The top motor for 74 was a 4 barrel 350 which was rated at 185. (10 MORE than 73, and more than any later Nova) It is code L-48 on the build sheet, and will have a "K" in the 5th place of the VIN. Of course if you plan on building your own motor this may not matter to you. All "K" engine Nova's also came standard with front disc brakes, which of course is nice. Nova's with other engines had discs as an option, so some have 4 wheel drums.
To see everyones "perfect Nova" see the ultimate Nova thread above.
