Go Back   Automotive Forums Car Chat > Nissan > 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX
Old 09-29-2006, 03:45 PM
Capecoral240 Capecoral240 is offline
Z32 Brakes
Will The 30MM Z32 brakes Fit on the 93 SE Rim? Or will i have to buy the 26MM? And do the just bolt right up or is minor MODing needed?
Get it sideways
http://www.cardomain.com/ride/2478891
Old 09-29-2006, 05:51 PM
AWDSR20 AWDSR20 is offline
Send a message via AIM to AWDSR20 Send a message via MSN to AWDSR20
Re: Z32 Brakes
http://importnut.net/300zxbrakeswap.htm
Read on my brother...
"A good driver is measured not by his lap times, but by the amount of time he spend trying to make sense of his car"
E.K.
Old 09-29-2006, 06:55 PM
240SXSlideStar's Avatar
240SXSlideStar 240SXSlideStar is offline
Re: Z32 Brakes
30mm will clear S13 stock rims with a 5mm spacer.
-Jonathan
JDM Racing Motors inc
Montreal, Canada
www.jdmracingmotors.com
Old 09-30-2006, 01:14 AM
slideways...'s Avatar
slideways... slideways... is offline
Re: Z32 Brakes
but you need redrilled rotors at least, and IIRC a caliper bracket.
Rice Police #1. dont argue with me just because you are a riceboy and/or have sand in your vagina. i am superior. and i am smarter than you. end of story.
Old 09-30-2006, 03:28 PM
Re: Z32 Brakes
Sounds a little to complicated.. would i just be better off geting ones for the s13 and spend the extra benjamins or save some $$$ and go with the z32 swap?
Get it sideways
Old 09-30-2006, 03:57 PM
D-Bo's Avatar
D-Bo D-Bo is offline
Re: Z32 Brakes
do it so that you have more options in the future. do the 5-lug swap and put on the biggest disc you can (jon says that 30mm fits.. i have 26mm and i need a 10mm spacer to clear the calipers and there's room to spare between the disc and rim) and put on the z32s with stainless steel line and master cylinder. that way you could put on s14 wheels or whatever other 5 lug wheels you want.. trust me your options are limited with 4 lug
Originally Posted by iVteC_PoWeR
to me when i really look at it hondas just too expensive and theres not much power even after you spend loads of money...
http://www.cardomain.com/id/dbo240
***LOOKING FOR A COUPE, ENGINE IS NOT AN ISSUE***
