Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 09-29-2006, 03:00 PM
Mikelb's Avatar
Mikelb Mikelb is offline
Send a message via AIM to Mikelb
High-flow fuel filter...
Is there a higher flowing fuel filter that I can use on my stock fuel lines...
I'm looking for one to go on the car until I replace the lines and upgrade the fuel rail...
Didn't know if there was any that was kind of a bolt-on part or not...
Thanks...
Originally Posted by Blackcrow64
I write a lot... I wrote one song about this chick I was messing with that was uhhh... Well, lets just say I called it "Forbidden Love"
1991 Eagle Talon TSI - Broken
Head removed, block broken, trans in hatch
1991 Eagle Talon TSI AWD- in pieces
3" exhaust, rebuilt bottom end
Project: Assemble the Eagle is underway... and now with AWD
2003 Lancer Evo 1630hp/1593ft lb tq
Old 09-29-2006, 03:09 PM
blk_srt's Avatar
blk_srt blk_srt is offline
Send a message via AIM to blk_srt Send a message via MSN to blk_srt
Re: High-flow fuel filter...
I'm pretty sure that the oe one is the only one that will bolt up with no modification
2004 Flame Red SRT-4
|Audiobahn 1200Q|Rockford 602s|Jensen flip out dvd|
Mods:
Old 09-29-2006, 03:19 PM
l_eclipse_l's Avatar
l_eclipse_l l_eclipse_l is offline
I've never heard of anyone having to upgrade to a higher flowing fuel filter....even those running massive setups. So you shold be fine with OEM.
'92 3000gt SL
Zoom Stage 1 Clutch
Originally Posted by kjewer1
I disagree. Better is better. Bigger is just bigger.
I just made that up, and I like it.
Old 09-29-2006, 03:26 PM
Mikelb's Avatar
I was looking at some running high hp numbers... and none of them have the stock one... I was told by someone else that the stock fuel filter is a low-flow design...
There's a whole webpage dedicated to this, I just can't member where it is...
Old 09-29-2006, 03:27 PM
Mikelb's Avatar
any that I can put new connections on the stock fuel line/rail to make fit?!?
Old 09-29-2006, 03:35 PM
blk_srt's Avatar
Hmm... If you add a rubber end and put on an AN fitting you could use the aeromotive unit
Mods:
Mikelb's Avatar
found it... http://www.stevetek.com/R-FuelSys.html
Old 09-29-2006, 03:36 PM
Mikelb's Avatar
if you wouldn't mind, could you get some part #s, like something I can go to Advance/Napa/Carquest/etc... and pickup... I'm just unsure of all of this, and don't wanna fuel leak(=disaster)...
^I mean, that's kinda dangerous, and I did just fix the oil leak... don't need anything else to leak...
Old 09-29-2006, 03:47 PM
blk_srt's Avatar
it actually tells you what you need on that site. I would follow those instructions
Mods:
Old 09-29-2006, 03:56 PM
Mikelb's Avatar
alright... I just didn't wanna have to order stuff... I would like to have been able to walk in my local store and pick it all up... but oh well, I'll do some searching for the parts then... thanks...
