Go Back   Automotive Forums Car Chat > Toyota > 4Runner/GX470
Old 09-29-2006, 02:17 PM
trainp01 trainp01 is offline
97 4runner dimmer light
my interior dimmer light know does not work. My main panel does not dim at all when I turn the knob. is there a fuse for that? How do I fix that?
Old 09-29-2006, 04:35 PM
KimMG KimMG is offline
AF - Advisor
Re: 97 4runner dimmer light
Since the lights are working, I would suspect the reostat has failed. You can use a meter to measure the resistance as you adjust the switch.
Does your dimmer switch have a knob or a wheel to adjust the illumination. If it has a knob, pull the knob off, remove the nut securing it to the dash, and remove the switch from behind. May have to remove a panel to get access to the switch.
Old 09-29-2006, 04:43 PM
it is a wheel that turns left/right. i don't have a meter. i can pull this wheel off and there will be a nut for to unscrew? let's assume this "reostat" is bad.....is this part behind the nut? sorry but i am new to this "reostat". Thanks
Old 09-30-2006, 11:28 PM
AF - Advisor
The reostat is an integrated part of the switch.
