Old 09-29-2006, 01:16 PM
guitarfish's Avatar
guitarfish guitarfish is offline
Angry What if wrong coolant (not DexCool) added ??
My wife is on a long trip, her low coolant light came on. She stopped at a convenience store and purchased some antifreeze and added a few cups to the coolant recovery tank.
I had told her to look for DexCool, or one of the brands that says "safe for all cars". Well, she says she didn't see either of those written on the antifreeze, so I have no idea what she added to the car.
If I assume that she added old style ethelyine glycol coolant that isn't compatible with DexCool, does anyone know that the results would be??
Old 09-29-2006, 02:02 PM
guitarfish's Avatar
Re: What if wrong coolant (not DexCool) added ??
Well, I found an article that explains the answer. The car won't blowup, at least.
Proper Coolant Use
Old 09-29-2006, 03:52 PM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Old style green (ethylene glycol) and OAT type coolants do not mix. They will start to gel and clog cooling system passages. My best suggestion if you don't have the bottle, is to get your system flushed before major problems develop.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 09-29-2006, 04:11 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Green and dexcool orange makes brown or mud.
As said if not sure flush it after 3 years or 50K it need changed anyway.
If leaking coolant it would be a good time to look for the leak to.
What engine and mileage? Any external coolant leaks?
MT
Old 09-29-2006, 04:30 PM
guitarfish's Avatar
I wasn't aware of any coolant leaks, but apparently there is. It's got 225,000 miles. I did the thermostat and fresh Dexcool about 20,000 mi ago. I'll probably just flush & refill when she gets back. Why mess around and take chances, ya know?
Thanks guys.
Old 10-01-2006, 04:48 PM
djstifft djstifft is offline
Although Dexcool is said to be good for 5 years, I don't trust that. Even if the coolant is still good, what about the wear (rust) from the system and the water pump? I got a GP 2000 that had it flushed two years ago and flushed the radiator yesterday. Although the coolant was still bright orange, I had some teaspoons of black and metallic "sand" in the bucket that could have build up and cloak the system if leaved in.
Old 10-01-2006, 05:37 PM
98gpking 98gpking is offline
Send a message via MSN to 98gpking
uummm if your getting that much build up in the coolant system on a 2000 you might wanna get something checked haha. the purpose and the reason why the orange coolant was used for theses reasons
-inorganic
-non toxic
it wont build up and create sludge, its also less likely to break down. i can see maybe some sand like substance but a few teaspoons....i dunno if thats good that didnt happen when i flushed out mine
2000 grand prix GTP. CAI, 180 t-stat, u-bend and res delete, custom tuned PCM, shift kit
