Go Back   Automotive Forums Car Chat > GMC > Sierra
Old 09-29-2006, 08:53 AM
cadiehl cadiehl is offline
Water sound under dashboard
1996 GMC Sierra 1500 SL Xtra Cab
I have a water gurgling sound under the dash at the glove box. This has been going on for about two years, and the A/C and heat work fine. I get a little condensate/water drippage from the area onto the rubber floor board. It hasn't seemed to be a big issue which is why I have not taken it to the shop. Truck runs great. What is this, and is it something I can easily remedy myself.
Thanks in advance for the help!
CD
Old 09-29-2006, 09:19 AM
east302 east302 is offline
Re: Water sound under dashboard
The condensate drain from the evaporator may be clogged, causing the condensate to fill up in the case and leak onto the floor. The drain line should be through the passenger side firewall...take a pipe cleaner or something similar to it. Do you normally notice water on the ground on the passenger side once you are parked? If not, then the drain is probably clogged.
For the noise, some say it's the heater core and common with these trucks. Try a search on the Chevrolet board, maybe they can help out some.
Old 09-29-2006, 02:34 PM
2000CAYukon 2000CAYukon is offline
I also own a 96 Chevy car. When I first bought it used, I also had the gurling sound coming from the dash. In my case, the cooling system had air trapped and needed to be bled. It has a bleeder screw on the tstat housing.
Not sure if the 96-99 Vortecs have a bleeder screw or not but your noise could be air trapped in the cooling system.
//2000CAYukon
Old 09-30-2006, 01:00 PM
horse482's Avatar
horse482 horse482 is offline
AF -Advisor
I have a '94 with the same problem, you can put a restictor in the inlet hose to limit the noise.
NO 4 N JUNK
1994 GMC K1500 XC 5.7L
2008 Chevy Impala LTZ
Old 10-01-2006, 07:51 PM
phipps phipps is offline
My 1997 Sierra will have the gurgling sound if the coolant gets low.
Old 10-02-2006, 10:44 AM
Mr. Smith Mr. Smith is offline
Send a message via Yahoo to Mr. Smith
You have air in the system....Purge it of air and the gurgle will go away.
